Question about kawasaki Full Suspension Mountain Bike Men
Belt light stays on on my kawasaki brute force 2005 model 750
The belt light stays on,on my 2005 Kawasaki brute force 750 4 wheeler
4 Suggested Answers
  • 168 Answers
SOURCE: the drive belt light is flashing on the dash and
This belt light is a feature put on by kawasaki for safety. It'll continue to come on after it get so many kilometers on it. The light has to be reset in order to get it off. Now if your mechanically inclined i'll explain to you how to get that light to go off.
First thing you have to do is reach down under the right side of the bike and in under the side cover you'll find two black plugin and two grey pluggins. Unplug those two and then plug a black and grey together and then the other black and grey together. Then down on the belt box you'll find a square black metal box with two wires coming from it. Unplug that ****** also. Once you have this all done now turn the ignition key to the on position and wait for about 7 to 10 seconds and the computer will reset itself. After you do that, turn the ignition key off and then unplug the two black/grey connectors and plug them back together, black to black, grey to grey. Then plug the connector from the black metal box on the belt cover back in. After you have this done. Turn the key on and let it go thru it's cycle. When you are done the belt light should be off.
Now if after you have done all this, and the belt light remains on and you still have no power, then you have a switch problem in the belt box. You can either remove the belt box and check the switch inside of it to see if the switch has been tripped to off. If it has, then in all probablity you need to install a new belt and reset the switch. Personally, i'd cut the two wires coming out of that metal box i previously told you about and join then together on the bikes wiring harness side. Leave the two wires from the black metal box like they are. You don't have any warranty on that part of the bike anyhow, so why bother have that switch continue to cause you problems. In order to get the belt light to off after you cut those two wires is you'll have to go thru the process i explained to you before. Only this time at the end instead of plugging the switch wires back together, just twist the two wires on the harness side together,in theory all you are doing is plugging that plug together, only your disconnecting that switch and never again should it bother you. However, after a few 100 kilometers you may have to do all i explained to you over again, only the next time you'll have to untwist the two wires along with the two black and grey wires and then go thru the process again. After the process is done, replug black to black, grey to grey, and then twist the two wires back together, turn the key on again and let it reset itself. Again your belt light should be gone out.
Good luck
Wayne
Posted on Nov 06, 2009
SOURCE: kawasaki brute force 750 2005,
Your jetting on the carbs are wrong.
if you want more info on the jetting and how to do it along with some GREAT info, check out highlifter.com/forum
Posted on Dec 18, 2008
  • 4 Answers
try to drain carb
water probably got in through air box and carb vent hose
drain and flush carb
replace spark plug
spray contact cleaner in carb throat through air box
Posted on Dec 19, 2008
I have a 2005 brute force 750 won't start with electric start it will start when I pull start it will run.when it's running the lites and display are flickering .
Sounds like your battery is about dead... replace the battery and clean the connectors/wires/terminals.. and a little waterproof grease will stop the corrosion. Make sure the new connections are tight!
Jan 25, 2017 | kawasaki 2005 Brute Force 750 4x4i
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
Brute force 2009 750 runs but will back fire an stop
How long since the oil has been changed? Is the oil level OK? It sounds like you have a sticky valve that hangs open once in a while.
Jul 31, 2014 | kawasaki 2009 Brute Force 750 4x4i
Belt light on Kawasaki Brute Force 750
Check YouTube.
There are a number of people that have made videos on how to resolve this issue. It involves making a small plug up and touching it across two terminals.
Jan 26, 2014 | Yamaha Kawasaki Genuine Kvf750 Brute Force...
Why does my brute force four wheeler barg down when I give it gas then it backfires
The float in the carburetor is possibly sticking. have the carb cleaned or run some carb cleaner through it.
Aug 27, 2013 | HMF Kawasaki Brute Force 750 08-11 Swamp...
Kawasaki atv
There is a video on Youtube
15# How to reset belt light - Kawasaki brute force 750i
Jun 19, 2013 | ATVs
good chance u have a bent rod, bent valve. Need to take to shop to get checked out.
Oct 30, 2008 | kawasaki Full Suspension Mountain Bike Men
kawasaki Full Suspension Mountain Bike Men Logo
61 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
