Question about Kyocera Cell Phones
My Kyocera torque will not start
I turned off my Kyocera Torque and now it will not start. It will turn on cycle through the sprint and or android screen then either shut off or lock up or continuously restart. How can I fix this without doing a factory restart? I don't want to lose the apps or anything else that are on my phone now.
  • Kyocera Master
  • 2,072 Answers
  • Try turning it on while having it plugged in.
  • If it still shuts off then a factory reset is probably your only fix, however you may have a bad EEPROM and in that case you would probably want to consider replacing the phone.
Posted on Mar 19, 2014
Arius
  • 446 Answers
SOURCE: My phone keeps shutting itself off once I tried to turn it on.
replace the battery pls
Posted on Aug 30, 2008
SOURCE: iphone froze
hold down the power button and home button for roughly 10 seconds sometimes it can take anything up to a 1minute. This almost always works. My froze and i tried this, worked first time.
When your screen goes off from holding them down. Plug you iphone into itunes and it will load and your all set.
Posted on Jan 07, 2009
Fixe_You
  • 1800 Answers
SOURCE: kyocera strobe phone crashed
uptading firmware will solve trhis kind of probllems!
Posted on Mar 27, 2009
jennfolino
  • 6 Answers
SOURCE: my kyocera wont turn on. when i plug it in to
i have had several of these handsets and i have noticed that there are several batteries that will fit into the battery compartment of the phone, however just because the batteries fit, that doezn't mean that it is the correct one. i went online and ordered the battery for this phone model on ebay several times and everytime, i got the same result: the battery fit in the phone, i plug it in to the charger and the phone would light up and say: PHONE IS OFF **** it did not say phone is charging**** when i turned the phone on (with it plugged in) it turned on and everything seemed normal except the battery icon was missing from the right hand top corner of the display. i looked up the kyocera website and looked up the compatibility matrix and it was absolutely 0 help. finally i figured it out because i buy and sell phones on ebay and i received a used phone with the battery in it and it worked, the # printed under the barcode on the front of the battery is 020609606036. i also purchased a brand new handset that was still in factory packaging and i took note of the # on this battery also and it was the same as above but the last two digits are 35. i have not researched any other batteries for functionality on this handset, however, there may be more that do. these 2 OEM batteries i listed above do indeed work in the handset for sure
Posted on Feb 16, 2010
drdarklord
  • 98 Answers
SOURCE: How do I unlock my samsung impression?
if you set the pass code on the samsung then what you need to do is take it to AT&T store. and ask them to remove unlock code. aka phone lock system.
Posted on Jul 04, 2010
Unable to get wi-fi to kick in and hold for a call. although it works just fine in store.
Troubleshoot issues related to data connectivity and your ...
support.sprint.com/...Kyocera.../WTroubleshootingGu...
Sprint CorporationThis article helps you troubleshoot data connectivity issues on your Kyocera Rise. You may have data connectivity issues if you're unable to: ... Some features and applications require a data connection to work properly. ... Note: Most Wi-Fi networkshave a range of less than 100 feet indoors and up to 300 feet ... Contact us ...
Troubleshoot issues related to your Kyocera Hydro Edge ...
support.sprint.com/...Kyocera.../WTrendTroubleshoot...
Sprint CorporationThis article helps troubleshoot your Kyocera Hydro Edge slowing, freezing, ... You mayhave performance issues if your device: ... back on; Displays error messages; Isunable to install or update applications ... Press and hold the Power key, tap Power off, and then tap OK to turn your Kyocera Hydro Edge™ off. ... Contact us ...
Brigadier by Kyocera Support ' Verizon Wireless
www.verizonwireless.com/support/brigadier/
Verizon Wireless
Dec 13, 2015 | Kyocera Cell Phones
My phone would not turn on. Did a complete wipe and restore . Now I have no network connection and none of my apps work. How can I fix it?
Hold power,volume dn kys down until beep then press home and hold all three down at same . Follow prompts from there like load back-ups . Hope you backed up your system. Good luck.
Nov 23, 2014 | Kyocera Torque Sprint
I have a Kyocera torque through Sprint, I no longer have the Sprint service and want to turn phone on through metro pcs....does anyone know if I can do that
As far as i know the answer is no. Metro runs on t mobile network, t mobile needs a removable sim card. Sprint and their phones does not work like that. You have to get a new phone with metro. The only phone companies that are compatible with metro, are t mobile, att&t, and I think cricket. You could try boost mobile, if I'm not mistaken ya they run on sprints network.
Nov 23, 2014 | Cell Phones
I need torque specification on head bolts on a 1996 concord Chrysler 3.5
First step-----45ft pound
Second step-----65ft pound
Third step--------65ft pound
Fourth step-------another 1/4 turn
Sep 10, 2014 | 1996 Chrysler Concorde
Bolt torque specs chart
go to dealer they will give you the tork specks on the bolt make sure to seral number modle number and what make of bike it is that way nobody could give you wrong tork spec and i seen it done by accident by not haveing a serial with a mid year tork change so go to dealer be for sure
Sep 01, 2014 | 2005 Triumph Sprint ST
How to get my kyocera torque to turn on
Unfortunately the phone is fried. I had this happen to me also. Took it in to a Sprint store and they ordered me a new one at no charge. Kyocera is still working out the bugs on this phone.
Jun 28, 2014 | Kyocera Torque Sprint
Kyocera torque keeps turning on and off and on and off
Im having thecsame problems :( it used to be great but now this phone drives me crazy
Dec 04, 2013 | Kyocera Torque Sprint
What do they mean by degrees when torqueing head bolts? i know thw ''old'' way of torqueing in three stages ot different ft.lbs,so how do you do degrees?
With the newer engines, you first torque to a specific torque in ft-lbs. Then, you have to use a tool called a Torque angle indicator, which you use with your torque wrench or ratchet, in order to turn the bolt a specific number of degrees after that to the final torque. This measurement is used with "stretch" bolts, which are a more precise method of torquing, and will also retain the torque during heating and cooling cycles, especially with aluminum heads and an iron block. I don't know which engine you have, but the 4.3 still uses the old method of torquing. Hope this answers your question.
Feb 21, 2010 | 2002 Chevrolet S-10
Cell Phones Logo
129 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
