Question about Bugaboo Cameleon Baby Gear
Break lever doesn't stay at break position - Cameleon Bugaboo Baby Gear
  • Bugaboo Master
  • 1,629 Answers
Hi Ye,
We would recommend you contact Bugaboo for assistance.
Bugaboo Official Site
Posted on May 12, 2014
Carburetor adjustments
What type of carb?
What YEAR/MAKE/MODEL bike?
Aug 31, 2014 | Motorcycles
Needle is moving up and down but it doesn't move forward
if you have a manual, check and see where the feed dog lever is and make sure it's in the up position. when the feed dog is in the down position it's in the darn mode staying in one place,, but when it's in the up position the machine will sew.
here is a link for a manual, if you don't have a manual
http://www.sewingpartsonline.com/instruction-manual-elna-2110.aspx
Jun 12, 2013 | Sewing Machines
My Needle just stitch in one place
check in the manual and see where the feed dog lever is a check to see if it's in the up position for sewing or in the down position for darning, if it's in the up position, then the machine needs to be checked to see if there is something wrong with the feeddogs or the feed dog lever..
Jun 12, 2013 | Elna Sewing Machines
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
Why does my traction off light come on?
You either have a problem with your engine control system, the traction control system, or you are not in the correct gear. See the explaination below. This is from the 2000 Chevrolet Cavalier Owner's Manual.
TRAC-OFF LIGHT
... If you turn the system off by moving the shift lever
to FIRST (1) or SECOND (2), the warning light will
come on and stay on. To turn the system back on,
move the shift lever back to a position other than
FIRST (1) or SECOND (2). The warning light
should go off. (See "Enhanced Traction System"
in the Index for more information.)
 The warning light will come on when you set your
parking brake with the engine running, and it will
stay on if your parking brake doesn't release fully.
If the transaxle shift lever is in any position other
than FIRST (1) or SECOND (2) and the warning
light stays on after your parking brake is fully
released, it means there's a problem with the system.
 If the traction control system is affected by an
engine-related problem, the system will turn off
and the warning light will come on.
If the Enhanced Traction System warning light comes
on and stays on for an extended period of time when the
transaxle shift lever is in any position other than FIRST
(1) or SECOND (2) your vehicle needs service.
Aug 08, 2011 | 2000 Chevrolet Cavalier
My locking dual brake lever does not hold in he PARK mode. The cables are as tight as possible without causing the brakes to drag.
If the lever stays in the park position but doesn't hold the wheel, then you'll need to have the brakes adjusted. They're likely not properly aligned with the rim, which is why the cables are tight, but not effective.
May 05, 2011 | Pyramid Alloy Mountain Bike Dual Cable...
I have the Delonghi DE500P and the lever that indicates the bucket is full will not stay down and therefore the bucket full light remains on and the fan will not start. when i use my finger to push this...
Replacing the switch/lever is more trouble and costly than it's worth. That's if you can find the part. I suggest, that you try reinstalling the bucket very carefully, making sure it making contact with the lever in the proper position. Lots of times, the bucket is simply not being inserted properly and it misses the switch. If that doesn't work and you want to repair it yourself. Contact Delonghi Parts Dept 800-865-6330.
Hope this helped you.
Apr 27, 2011 | DeLonghi DE500 Dehumidifier
1998 Accord: 1998 honda accord sedan break lights stay on...
In all probability, the brake switch got stuck in the closed position. One way to test it is by trying to move the shift lever from Park to Neutral without depressing the brake. If you can do this, then the switch is damaged. It is very simple and inexpensive to replace.It is located a few inches above the brake pedal rubber pad.
May 17, 2010 | 1998 Honda Accord
Gear shifter does NOT shwitch from park and break
SHIFTER LOCKED IN PLACE
  1. Remove the instrument panel cover below the steering column, then remove the steering column shrouds to gain access to the brake transmission shift interlock (BTSI) solenoid. The solenoid is part of the interlock cable assembly.
  2. Disconnect the wire connector from the rear of the BTSI solenoid.
  3. Insert the ignition key and turn it to the ON position.
  4. With the brakes applied, try moving the shifter out of the PARK position.
    • If the lever now moves freely in and out of PARK, perform the Circuit Test below.
    • If the shift lever still does not move from the PARK position, remove the BTSI solenoid from the shift lever assembly. If the shift lever now moves freely in and out of the park position, the BTSI solenoid is faulty and the interlock cable must be replaced. If the shift lever still does not move from the park position, the problem is in the shift lever assembly or the ignition interlock cassette
May 09, 2009 | 1998 Honda Accord
Baby Gear Logo
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
