Question about Whirlpool Washing Machines
Broken dial/selection knob on whirlpool wfs1072aw-7.5
THe front know/dial isn't working, I guess it isn't catching on whatever mechanism is behind it to swap between cycle types. Is there a safe way to take off the knob or front panel to fix this?
    Problem Solver:
  • 4 Answers
The knob should pull straight off or it should unscrew counter clockwise. What is the model number of the machine?
Posted on Mar 19, 2014
  • 4 more comments
  • Katie Yeung
    Katie Yeung Mar 19, 2014
    It's a wfs1072aw-7.5 The knob can do selections by turning either way so it does not unscrew.
  • dexl1200 Mar 19, 2014
    I tried to pull up that model # from the parts supplier website that I use and it is showing as a bad model number
  • Katie Yeung
    http://www.productreview.com.au/p/whirlp...
    That still didn't bring up anything can you get it off the machine itself should be right inside the door
  • Katie Yeung
    As the review says, the model is discontinued. From in side the door: wfs1072aw
    without a good model number I can't pull up a parts illustration of the machine sorry I couldnt be of further assistance
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
SOURCE: Dial on the washing machine is broken
how do i open a WSCR2090g top load washer
Posted on Sep 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: In a rush to leave
You should be able to push and hold the Cancel button to clear the cycle.
Posted on Aug 21, 2011
Why can't I hear the timer ticking?
The timer, if it's the mechanical type that you have to push in the knob to select cycles, then pull out to start, is *not* repairable. From what you are describing, it sounds like the internal mechanism had broken and the timer needs to be replaced. There is a specific, small procedure for removing the dial and replacing it on the new timer--if you are unsure on how to do this, get a qualified tech to do it--otherwise you run the real risk of breaking the mechanism in the new timer. I hope I helped you!
Aug 10, 2015 | GE Washing Machines
Changing pump on whirlpool washing machine WFS1072AW. I need a new pump (so I've been told as the single part isn't available for sale) as I've broken the black screw/cap that seals the pump. I...
take your new pump back and look in the paper for someone who sells used washers and call to see if they have the part u need,they getthe washers for free to remove may have what u need
Sep 17, 2011 | Whirlpool Washing Machines
Front loading whirlpool machine WFS1072AW which needs pump clean
WFS1072AW has a clip in panel at the bottom across the front.
Removing this will reveal a black plug on the right.
Unscrew this and water will gush out along with (hopefully) the offending coins.
Feb 13, 2010 | Whirlpool Washing Machines
I have a whirlpool WFS1072AW washing machine. a red light comes on to clean pump. I am not sure how to do it
The WFS1072AW has a clip in panel at the bottom across the front.
Jan 07, 2010 | Whirlpool Washing Machines
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Water leaking and dial spinning
unconnected faults. does water come out of drawer when filling? if so fault is a blockage in hose down to tub from drawer or drawer may need cleaning if fault happenns on rinse. fault on knob is broken inner knob and poss cam as well
Mar 14, 2007 | Zanussi FLA1201W Front Load Washer
Washing Machines Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
