When was the toilet made
Need to know when the toilet was made
  • 2,072 Answers
If it still has a sticker with the serial # (may be in the tank) you might be able to call the manufacturer for the date
Posted on Mar 19, 2014
How do you know if a toilet should be replaced?
Your toilet should be just fine,I have 2 toilets that run to a septic tank,the newer one gets clogged up cause of the new regulations that only 1.2 gallons is used per flush which means it needs to be flushed more often than the old type I have,the new one,they are problematic.On your case,are you using a lot of paper,if so,then flush more often.Your plunger may have a pin hole in it,not letting you unclogged,Flush toilet,then plunge quickly.You may need a new plugger,they have better types now,Walmart has them.
Aug 20, 2017 | Home
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
CAN'T IDENTIFY THE MODEL OF MY TOILET AND SEAT
Look inside of the tank the number will be stampes into the porcelin of the inside of the tank...
heatman101
May 26, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I need to know exactly how to adjust the toilet tank fill valve on a hoov-r-line 8121-1AS or get a link to a user manual
There should be a screw on top, usualy plastic that once flushed can easily be turned to adjust the tank level. Usualy half turn at a time will make a pretty substantial change. I hope this helps.
May 14, 2010 | Home
Can't find the right toilet seat from standard stores
Grohe does not make toilets. look inside the tank for manufacturer and model number it sounds like a one piece toilet and the seat bolt nuts are in the tank feel around for them.Grohe only makes handles for toilets to match their faucet finishes
Nov 14, 2009 | Grohe 28917ZB0 Oil Rubbed Bronze Relexa...
I need a tank LID for the 270 Caravelle dual flush toilet. Where can I get one fast? A customer broke the lid in a thousand pieces and we need a replacement ASAP.
Toilet seats are standard and fully interchangable. You should be able to pick one up at your local hardware store. The only thing you need to know is if you have a round or elongated bowl.
Sep 18, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Toilet tank not filling
shut the water off to the toilet .Remove the toilet supply from the tank end.slowly turn the valve on to see if their is any water coming thru the supply.If water is coming thru the supply than you know you need to change the ballcock.This is the part in the tank where the water comes out of.
Feb 01, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
