Question about Staples SPL-P100 Printing Calculator
Paper doesn't move
The figures clculates, but the ribbon is installed but does not move through.
Calculator does not print since new ribbon was installed
Take the paper roll and ribbon out and see if those gears move. If they do, then you have the ribbon badly placed. They are also notorious for the ribbon itself not being flat and sitting correctly.
Jun 18, 2016 | Sharp EL-1197PII Calculator
How do I install a swintech 8011 typewriter ribbon. having some major issues
There is a red handle on the right side carrier , pull it towards you and to the left, remove the old ribbon, set the new cassette in place threading it thru the two guides, turn the knob on top to take out slack, move the red handle back.
DickyO
Jan 27, 2015 | Office Equipment & Supplies
IBM Wheelwriter 6 - Ribbon doesn't lift high enough for the key that's pressed to print on paper. Ribbon advances OK.
If theribbon dosen't lift at all see if the black gear on the R. side of the printer will move, if not w3iggle it and it should free up they get tooth for tooth with the motor gear. If it only lifts partually thereis an adjustment on the roll that works with the black gear. BE SURE TO CHECK THGAT BTHE PLATEN IS FULLY SEATED IN THE VSIDE FRAMES THEY DO GET LOOSE!
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
Nakajima typewriter model AE830. New ribbon installed. when typing printed letters appear only lightly printed on paper. Any way to adjust?
Check to see if the ribbon is moving, then advance the ribbon manually about 6 inches, the ribbon may be old and they do go bad especially the exposed part. If the ribbon isn't advancing Code peroid, comma or slash will get you out of the overstrike mode.
DickyO
Jun 24, 2010 | Nakajima Office Equipment & Supplies
Doesn't type on paper.
NP means normal print.  it should be printing. check to be sure ribbon is installed correctly and is moving, you can turn knob on ribbon and look at ribbon to see if it is moving.  see if ribbon is used up. also make sure printhammer is latched forward
Jan 13, 2009 | Nakajima AE-740 Typewriter
Wheelwriter 5
You probably need the plastic cap that is on the proint solenoid, they are available but a little tricky to install.
DickyO
Sep 30, 2008 | Lexmark Wheelwriter 3 Typewriter
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Ribbon retainer clip installation??
Possibly came from the ribbon cartridge. Try another ribbon.
Mar 27, 2008 | Swintec 7040 Typewriter
Staples SPL-P100 Printing Calculator Logo
29 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
