Laptop monitor I have a hp probook4530.The brackets that hold the monitor to the keyboard have broken off leaving only wires connecting the 2 together...How can this be repaired
    Master:
  • 966 Answers
Nikki, it's a hardware issue and you should seek hp's help. Chances are you may not get but look for similar unit on craigslist or kijiji etc. You might get lucky. Meantime make sure wires are secure. One thing I would do is this. If the pieces are there, glue them with Crazy glue or similar strong adhissive.
Posted on Mar 19, 2014
Testimonial: "Hardware?You mean like the shell/case?"
Are hp laptop and dell monitor compatible?
Without knowing the model numbers of both it could be impossible BUT if you have a connection on the computer that you can hook the monitor to, the F4 key is the one that switches from the laptop screen to the external one. Hold down the key that says Fn and while holding press the F4 key above the number keys on the top row at the keyboard. You should get some activity on the monitor.
Jun 24, 2014 | Dell E176FP 17" LCD Monitor
Hp compaq 6710b external monitor works, laptop screen lights up but is blank
You need to just find the 2 keys on the keyboard that control the monitor outputs. 1st is the FUNCTION key located down in the bottom left near the CTRL and ALT buttons. Secondly find the function key going along the top of the keyboard (F1 to F12) that looks sort of a monitor, and a line on each side of it. Next depress and hold the function key (bottom), then press the monitor key (above). You do have to wait 1 or 2 seconds for the laptop to change modes as it will not be immediate. The 3 modes are Laptop only, Laptop & External, or External only,if you miss the mode needed then keep performing this until the correct mode is showing on the two monitors.
Good Luck!
Rich Lilja
Apr 03, 2014 | HP Compaq 6710b Notebook
Fix black screen
Computer got you stressed?....................Life getting you down?...
Feel like if one more tiny problem comes up, you're just going to end it all?
.........GET OVER IT!
"$^&%^*&& HELP ME PLEASE #@%^&&^%^&*"
Don't ever come to this website, and post that again
Help me please?..................Yes
Moving on................
An external monitor works
Good. This way you know the problem is either the Video Cable, or inside the Display Assembly.
Video Cable:
With the Compaq Presario C700 series of Notebook PC's, the Video Cable connects to the motherboard; in an area under the Keyboard, and Switch Cover.
(Above the F4 key)
It then leads under the left Hinge, and up into the Display Assembly.
From there a small cable branches off, and connects to one side of the Screen Inverter.
The main part of the Video Cable, goes on to connect to the back of the LCD screen.
Example of Video Cable,
http://www.amazon.com/G7000-Compaq-presario-Video-cable/dp/B005NEPKTE
The large connector on the Right side, connects to the back of the LCD screen.
The smaller connector shown at Bottom connects to the motherboard.
The small cable leading up to the Top/Left, connects to the screen Inverter.
http://www.ebay.com/itm/New-COMPAQ-Presario-CQ50-CQ60-HP-Pavilion-G50-G60-G70-LCD-INVERTER-486556-001-US-/281024427508?pt=LH_DefaultDomain_0&hash=item416e5c75f4
Just from repeated normal opening, and closing of the laptop; the Video Cable may become pinched, and pulled on. Sheath of Video Cable also hardens over time, and this also adds to the equation.
However, this laptop has been dropped. There's a real good chance of a problem with the Video Cable.
Pulling on it can lead to the connections coming loose.
Motherboard side, screen Inverter cable, and LCD screen side.
Procedure is to go through the various connections, and PHYSICALLY check them. Try to plug them in tighter.
Motherboard connection:
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Disconnect the Keyboard, HOWEVER do not disconnect the Keyboard Cable from the motherboard.
Once Keyboard is removed from Palm Rest Cover, take the LCD screen side, and roll the Keyboard over.
Bottom side up, lay on Palm Rest Cover.
3) Now remove the Switch Cover.
The Switch Cover is the wide strip of plastic, above the Keyboard, and below the Display Assembly.
The Switch Cover is just that........a Cover.
No wires attached.
Physically check motherboard connection.
Reinstall power. Turn laptop on.
No change?
Remove ALL power again.
LCD screen side connection and screen Inverter connection:
4) The plastic frame in front of the LCD screen, is the Display Bezel.
Remove it.
Right behind the Display Bezel, and mounted on the bottom/middle of the Screen Frame; is the screen Inverter.
Just physically check the screen Inverter connection, but go on to the LCD screen side connection.
The LCD screen is an assembly of layers. These layers are held in the factory set position, by a metal Screen Frame.
Resembles a picture frame.
Attached on either side of the Screen Frame, are Brackets.
The brackets are attached to the Hinges, and the whole assembly is just referred to as a Hinge.
There are screws that hold the Hinge brackets to the Screen Frame. There are also screws that hold the Screen Frame together.
Be SURE as to which screws you remove. You do not want to remove the Screen Frame screws.
Remove the screw that hold the Hinges to the Screen Frame.
Tilt the Top of the LCD screen forward towards you, and physically check the LCD screen side connection; of the Video Cable.
Lay the LCD screen back, put a screw in on each side, to temporarily hold the LCD screen in place.
Reinstall all power. Turn the laptop on.
Still no joy?
Remove the Video Cable.
The Video Cable needs to have a continuity test performed, with a multimeter set to OHM's. (1K)
Every wire in the Video Cable is checked.
No reading on a wire indicates a stretched/broken wire.
An assistant should also be used, to gently wiggle the Video Cable while checking.
An intermittent reading on the multimeter indicates a stretched/broken wire.
Or take the Video Cable down to the nearest small computer repair shop, and have the resident tech check it for continuity.
Should only be a coupla' bucks.
The Video Cable MUST be ruled out, before going on........
5) Video Cable checks out OK, or a replacement is used; and still no display on laptop's internal monitor, the screen Inverter is next in the diagnosis.
To test a screen Inverter requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to this, the ease of accessing to replace, and the usually low cost; the screen Inverter is just replaced.
6) If the new replacement screen Inverter brings no joy, then the problem is the LCD screen.
HP Support > Compaq Presario C700 series of Notebook PC > Manuals > Service Manual,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3559331&
Scroll down, and click on -
HP G7000 Notebook PC and Compaq Presario C700 Notebook PC - Maintenance and Service Guide
At the top is the Adobe Reader page number box
Page 21 is the start of the Illustrated Parts Catalog.
The next page shows you an exploded drawing of the laptop.
Page 58 - Keyboard
Page 61 - Switch Cover
Page 63 - Display Assembly
http://armbrust.dyndns.org/tips/presario700/
http://www.youtube.com/watch?v=nALcYwgVCZk
The F700 HAS wires to the Switch Cover. The C700 does not.
Just posting to give you a hands on look, instead of just a Service Manual.
02:59 - Here you can see how I described LEAVING, the Keyboard Cable attached to the motherboard, and just rolling the Keyboard over onto the Palm Rest Cover.
In Spanish, but a 'Picture is worth a thousand words', they say,
http://www.youtube.com/watch?v=55Wcej_K3ag
Not the Presario C700, but shows in better detail on releasing the Lock Clips (Detents), at the Top of the Keyboard,
http://www.insidemylaptop.com/hp-2000-laptop-disassembly/
Specifically photos in Steps 9 through 11.
Regards,
joecoolvette
(You won't need an ESD wrist strap for this procedure. However if you have one, wear it by all means.
IF, you remove the Palm Rest Cover, then you better be wearing an ESD wrist strap; and have it's alligator clip attached to a good ground source )
Apr 06, 2013 | Compaq Presario 700 470024-192 Notebook
My hp dv5000 screen is blank
Problem can be;
A) Graphics chipset
B) Video Cable
C) screen Inverter
D) LCD screen
Let's diagnose, and find out.
A) Graphics chipset:
To start off with, the Pavilion dv5000 series of Notebook PC's; is NOT known to have a problem with the graphics chipset.
The Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series; does.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port; on the laptop.
The VGA port is on the Left side of the laptop, and located towards the rear.
This is a general example of a VGA connector (port), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for VGA Cable example.
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not:
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no? Hold the Fn key down again, and tap once more on the F4 key.
No display on external VGA monitor, suggests a problem with the graphics chipset.
(Most of the time it is a problem with the Mounting, of graphics chipset TO motherboard. If this proves to be your problem, state in a Comment )
Display on external VGA monitor means the problem is the Video Cable, or inside the Display Assembly.
(screen Inverter or LCD screen)
B) Video Cable:
The Video Cable plugs into the motherboard, in an area under the Switch Cover.
(Left side.
Switch Cover is the plastic cover above the Keyboard, and below the LCD screen. Has the Power On Button, LED indicator lights, etc in it)
It then loops by the left Hinge, and goes up into the Display Assembly.
There is a small separate wire that comes from the main Video Cable, and connects to one side of the screen Inverter.
The main part of the Video Cable goes on, to connect to the back of the LCD screen.
http://www.batterycentury.com/hp-430531-001-cable-p-215726.html
Click on image to enlarge.
The wide connector you see at the top/left, connects to the back of the LCD screen.
The wide connector at the bottom/right, connects to the motherboard.
The single cable (Wire) coming off at the bottom, connects to one side of the screen Inverter.
Just due to normal repeated opening, and closing of the laptop; the Video Cable may become pinched.
This leads to it being pulled on, and may also lead to damage of the Video Cable.
(Stretched/Broken wires)
Procedure is to Physically check the connections of the Video Cable. Visual inspection alone will NOT do. You need to physically see if you can plug the connection in tighter.
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Remove the Switch Cover.
[Switch Cover is just that. A Cover. I will give a link to a free Service Manual from HP Support, towards the bottom of this solution ]
Try to plug the Video Cable connection at motherboard, in tighter.
Once done reinstall the Battery, and attach AC adapter. Plug AC adapter into power.
Turn the laptop on.
Still no? Turn laptop off. (Hold down on Power On button)
This time check the Video Cable connections at screen Inverter, and back of LCD screen.
The plastic frame in front of the LCD screen is the Display Bezel.
Example,
http://www.ebay.com/itm/447997-001-HP-Pavilion-LCD-Display-Bezel-DV9000-Series-w-Webcam-GENUINE-/170992584210?pt=US_Laptop_Screens_LCD_Panels&hash=item27cff3c612
Service Manual indicates to remove Display Assembly from laptop, in order to remove Display Bezel.
IMHO this = NO.
I think you can remove the Display Bezel, without having to remove the entire Display Assembly.
This video details removing the Display Assembly.
Shows replacing the LCD screen.
http://www.youtube.com/watch?v=NNyvf4KqeIY
What my concern is with removing the Display Bezel, is the integral Hinge Covers that are a part of it.
I believe the Display Assembly can be tilted far enough back, that the Display Bezel can be removed, and carefully ease the Hinge Covers out/off at the same time.
Why not just remove the Display Assembly?
A whole lot less stuff to reconnect, after you have checked the LCD screen connection of the Video Cable, and screen Inverter connection.
After disconnecting the LCD screen from the Hinge Brackets, you just tilt the LCD screen forward, and check the Video Cable connection.
Then slightly tilt the Display Cover back, so the LCD screen can rest against it, and reinstall power.
Connections are plugged in tighter, and this proves to Not be the problem, go on.
(Don't forget to remove ALL power again)
The Screw Covers are made of synthetic rubber, or plastic.
They are held in place by a type of rubber cement.
I like to use a computer pick, (Much safer than a blade!), and lift up at the base of the Screw Cover.
I also like to GENTLY stick them to the Display Bezel for safekeeping. (They like to stick to the tool, your fingers, and it seems passing cars. "Oops, dropped one. Where'd it go? Hmmmm)
If you are careful with them you can reuse them. (Doesn't stick anymore? Apply a TINY dab of rubber cement to them, with a toothpick)
Screws removed, I suggest cut a piece of thick construction paper, that just fits the inside edges of the Display Bezel.
Helps prevent scratching the LCD screen, from your fingernails, when you go to flex the Display Bezel, and remove it
The LCD screen is an Assembly of layers. They are held in the factory aligned position, by the metal Screen Frame which surrounds them.
There are screws that hold the Hinge Brackets TO the Screen Frame, and there are screws which when removed, will take the Screen Frame apart.
ONLY remove the necessary screws which hold the Hinge Brackets, TO the Screen Frame!
More in a Comment.
Regards,
joecoolvette
Feb 24, 2013 | HP Pavilion dv5000t Notebook
The 450sx4 screen is bright but no video
Many computer users spend long hours online every day and don\'t realize that looking at a bright laptop screen can be hard on the eyes. If you spend a lot of time in front of a laptop screen, consider reducing the brightness of the screen at the earliest opportunity. There\'s a quick and easy way to perform this task so you can save your eyes as well as your battery power.
Press and hold the "Fn" key on the laptop keyboard. This key is usually located at the top right or bottom left of the keyboard. Press the "Up Arrow" and "Down Arrow" keys, which are usually located in the lower right of the keyboard, to increase or reduce the brightness of your laptop screen. Adjust the level so that you can gaze comfortably at the screen without any glare. Disconnect the battery charger from your laptop and repeat the above procedure. On some laptops, the screen brightness varies considerably, depending on whether or not the device is charged. Hope this helps.
Jan 22, 2013 | Gateway 450SX4 Notebook
I can only see half of my screen
I suggest you have a bad LCD screen.
HOWEVER the procedure is to diagnose, and not spend money foolishly.
I need to know the laptop manufacturer name, and model number.
I cannot for the life of me believe FixYa would not ask for this, as a general requirement.
The model number is on the Bottom of the laptop.
Post back in a Comment.
In the meantime,
1) Check the graphics chipset first.
Connect a VGA monitor to the VGA port, on the laptop.
If the VGA monitor shows the same horizontal split of the LCD screen, then your graphics chipset is bad.
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
This is an example of a VGA Cable, and VGA connector (Port),
Scroll down a little for an example of a VGA Cable.
Turn the laptop on.
By factory default settings the display should show on the external monitor.
IF not;
There are at least 3 display options;
A) Internal monitor of laptop ONLY.
B) Internal monitor of laptop AND external VGA monitor.
C) External VGA monitor ONLY.
Here's where it gets rough, Dawn;
Hold the Fn key down, and at the same time tap once on the Display Toggle-Over key.
What key is that? Dunno. Laptop manufacturer name, and model number wasn't stated.
HP is usually the F4 key.
Acer? F5 key
Lenovo/IBM? F10 key.
The F key at top should have a monitor outline symbol, and an arrow on one side; for the Display Toggle-Over key.
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
Same display of internal monitor on the external VGA monitor?
Bad graphics chipset. Actually it is probably the MOUNTING of the graphics chipset TO motherboard.
More on that if it is the problem.
Good display on external VGA monitor?
Problem is the Video Cable, or inside the Display Assembly.
2) Video Cable:
The Video Cable connects to the motherboard, (In an area under the Keyboard, or Switch Cover above it), runs under the left Hinge; and up into the Display Assembly.
From there it may have a small cable coming from it, that connects to the screen Inverter.
The main part of the Video Cable then connects to the back of the LCD screen.
CCFL backlighting uses a screen Inverter.
(Cold Cathode Fluorescent Lamp)
LED backlighting May, or May Not.
Due to repeated normal opening, and closing of the laptop; the Video Cable may become pinched.
This can cause pulling on the Video Cable, and loose connections.
It can also cause damage to the tiny wires inside the sheath, of the Video Cable.
(Stretched/Broken)
If you see apparent damage to the sheath of the Video Cable, suspect damage to those wires inside.
Loose connection of Video Cable TO motherboard, or TO screen Inverter, (IF used), or back of LCD screen connection.
The procedure is to remove what components are needed from the laptop, to access the motherboard connector side of the Video Cable; and PHYSICALLY check to see if it is plugged in tightly.
{Components may only be the Switch Cover.
Above Keyboard, and below LCD screen. Has the Power On button, indicator LED lights, and perhaps speakers.
May be the Switch Cover AND Keyboard.
May be the Switch Cover, Keyboard, and Palm Rest Cover; in order to access the motherboard connector of the Video Cable }
Disconnect the LCD screen from the Display Cover, to access the LCD screen side connection, of the Video Cable.
Once all connections are proved to be tight, try the laptop again without fully reassembling. See if you can connect everything, with the LCD screen sitting out a little. Perhaps the Switch Cover off, but wires connected.
HOWEVER of you see apparent damage to the sheath of the Video Cable, or if you don't; the Video Cable MUST be ruled out before going on.
Connections tight? Didn't repair the problem? Remove the Video Cable.
A continuity test of the Video Cable must be performed, with a multimeter set to OHM's.
EVERY wire in the Video Cable must be checked for continuity.
Also an assistant is needed to gently wiggle the cable in the middle, and see if you get an intermittent reading on the multimeter.
If so this indicates a broken wire inside the Video Cable.
Replace.
Not everyone has a multimeter laying around.
Suggest take the Video Cable to the nearest small computer shop, and have the resident tech check it for continuity.
Should only be a couple of bucks.
(They say they can't check it? GET OUTTA THERE!
That ain't no REAL tech! Lol!)
Video Cable checks out?
Then the next component to check is the screen Inverter, again IF used.
Problem is to check a screen Inverter requires a sensitive multimeter.
For the above reason; the ease of access to replace, (Just remove Display Bezel), and usually low cost; the screen Inverter is usually just replaced. Average cost is around $20, or less.
Screen Inverter isn't used? Problem is LCD screen.
Screen Inverter replacement didn't repair the problem?
I know the above may look like, "Wah, wah, wah", from Charlie Brown. (That's what my niece tells me)
If I had the manufacturer name, and model number, I may be able to give you a link to a Service Manual, and possibly pictorial, or video guides; PLUS step by step info from me.
Makes it less, "Wah, wah, wah", lol!
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.insidemylaptop.com/taking-apart-hp-pavilion-dv7-laptop-guide-3/
http://www.insidemylaptop.com/how-to-replace-screen-on-hp-pavilion-g7-laptop/
http://www.manualowl.com/m/Acer%20Computers/Aspire-7738G/Manual/114625
Jan 21, 2013 | Computers & Internet
No display on laptop
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 29, 2012 | Computers & Internet
Broken led brackets in the base section, severed wires from monitor to base. Broken keyboard frame and keyboard. Cooling fan (thermal) damaged and heating up. Framework around the dvd enclosure is...
Id have a look on ebay with you model specs for all sorts of spare parts even broken complete pcs,some pcs have good spare part availability but others are difficult to find--good luck!
Davey Snake!
Oct 23, 2010 | Computers & Internet
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
"no signal" message when laptop is plugged into projector
There is a key on the keyboard that has blue text on it. Something to the effect of LCD or CRT. With the monitor connected and turned on, press and hold the FCN KEY as well as the LCD/CRT key. While holding the FCN key keep hitting the CRT key until the image transfers to the external monitor
Apr 17, 2009 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
