Question about Camping, Backpacking & Hiking
Amaze the two small holes appeared on one side corner.
Is there a built in microphone?
Take a look at the right edge just below the right corner of your keyboard. look for a small hole and itshould have a very small microphone icon on the left side slanted about 45 degrees.
Dec 03, 2010 | Acer Aspire 5500 5570-2609 Laptop
Ge side by side ice maker flap does not close how does frt panel come off
Take a look at the picture. The arrows are drawn to 2 small locks. Take a small screwdriver and press up in the hole then lightly pull that corner. Once you get that off you will be able to see the rest of it.
Thanks,
Barry
Oct 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How can i clear error c-0521
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note : On the7915/7920,after opening the front door,it is in the lower right corner.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
Dec 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do you set the clock on a 1995 Chrysler LHS with factory stereo
There are two small push pin holes in the front of the radio,on the right hand side upper right corner.turn key on first,use a pen or pencil and push in on the left hole,it is the hour setting,the right hole is for min.
Nov 18, 2009 | 1995 Chrysler LHS
I can not get in to my pocket pc hp ipag on start . after turning it on a small lock appears on the top left and after a while a screen will appear asking me for a password which I have forgotten. so it's...
you can try a hard reset(hold the 2 corner buttons down then using stylus insert in the small hole on the back for soft reset) this will restore factory settings. if you have sync folder on your computer you should be able to retreive contacts, pics, etc. hope this helps.
Sep 21, 2009 | HP iPAQ RX1955 Pocket PC
Drain pan leaking
silicone the corners
Jul 08, 2009 | Heating & Cooling
KitchenAid Mixer stopped working after I took the black screws on the side out. Thought that I put it back in right with the springs. Maybe I didn't. What could have happened? Thanks Nancy
The brushes must be insert in a particular manner in order for it to work correctly. If you remove the brushes and shine a flashlight into the hole, you should see a small detent or "stop" in one corner of the hole. Its a square hole. Match this corner with the corner of the brush which is shaved off. The brush is not square; it has one corner shaved or smoothed down. This allows the brush to fully extend into the hole. If the brush is inserted any other way, it will not contact the motor and will not run.
Apr 24, 2009 | KitchenAid K45SS Classic Stand Mixer
Kenmore Bottom Freezer Ice maker installation
in the bottom style freezer the plug will be in the upper left hand corner of back of the freezer ,,, may have a cover plate over it but thats where it is and should be a couple small holes with plugs on the upper left hand side for the mounting screws / larry
Dec 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Kitchenaid 350 stand mixer power problems
I'd check the brushes. The big black screws on the side of the motor casing, easily removed, but becareful when you put them back. Here were some instructions from another site that helped me get them back in right:
The brushes in my model KP50PSBU must be insert in a particular manner in order for it to work correctly. If you remove the brushes and shine a flashlight into the hole, you should see a small detent or "stop" in one corner of the hole. Its a square hole. Match this corner with the corner of the brush which is shaved off. The brush is not square; it has one corner shaved or smoothed down. This allows the brush to fully extend into the hole. If the brush is inserted any other way, it will not contact the motor and will not run.
Jun 01, 2008 | KitchenAid KSM50PR Professional Series...
SMALL ICON APPEARS ON THE SCREEN (TOP L/HAND CORNER)
Hi there
Have you tried pressing the Menu button when this happens ?
Dec 12, 2007 | Office Equipment & Supplies
Camping, Backpacking & Hiking Logo
509 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
