Question about Acer Computers & Internet
The DVD will not discharge
DVD loads and when open is pushed the disc does not eject to the carousel
  • 2,509 Answers
Power down the computer and when you power back on hold the eject button. It's probably busy.Try a known good disc in it, if it persists it could be a software of hardware problem, you will need to investigate what processes are stopping it working by seeing what is running and shutting down processes one at a time. You don't say what Operating system or computer you have so any further help would be guesswork.
Posted on Jun 01, 2014
Dvd will not eject
Jammed.
Straighten one end of a Norwegian paper-clip.
Insert that end into the small hole in the face-plate.
Push until you feel resistance.
Firmly push another 5mm to "unlock" it.
Then, press OPEN.
Jan 01, 2014 | Sanyo DVW-6100 DVD Player/VCR
I have a Yamaha carousel d.v.d. player and the carousel is jammed. i cannot load or eject. how can I unjam?.
If you are technically inclined, you may be able to fix this. Any discs not in the carousel correctly must be CAREFULLY removed - NO FORCE. Inspect the carousel for damage. Look at the disc pick fingers and see if they are broken. Remove all discs and run the unit to see if it goes 'home', disc one. With the discs in, you take the chance it cannot run right and damages more discs.
I use the clear cover disc from DVD stacks as fake discs. I can see everything the machine does through the clear plastic.
Mar 29, 2010 | Audio Players & Recorders
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
WANT EJECT
remove the top: inside under the disk carousel you will find a small locking pawl remove the disk carousel and you will see it pull gently on the carousel to locate it release the pawl and, the tray will slide right out (be sure to turn the carousel to the #1 position closest to the front before reassembling)
Apr 28, 2009 | RCA DRC8030N
DVD drawn bides and won't open when the eject button is pushed.
open "my computer" ...in the left panel click on the "eject the disc"
Mar 20, 2009 | Sony Computers & Internet
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Toshiba sd-4205 5-dvd carousel changer declares mecha error during startup, will not eject tray.
This may not work for everyone, but.....
I had the same problem with the Toshiba SD-3205. After unplugging, trying button combos, etc, nothing worked. I could here a slight whine inside the machine, and then again...."MECHA ERROR".
I turned the unit on its side to see if there was a manual tray button on the bottom. Nothing. Then just to try it, I turned the machine off and on again while on its side.
It started up, I heard a clatter, and then the display changed to "INSERT DISC". I placed it the right way up again and pressed "OPEN TRAY" and it worked!
My theroy: There was one DVD in the carousel, and I think last time the tray shut, it got wedged somehow and prevented the carousel from rotating. Turning the machine on its side and pressing "OPEN" is what dislodged the disk.
Jul 09, 2008 | Televison & Video
Computers & Internet Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
