Question about Amana ARB2517CC / ARB2517CB / ARB2517CW Bottom Freezer Refrigerator
Compressor is HOT, coil is not warm
My freezer is cool but not freezing. My compressor is running constantly and is HOT to the touch however the condenser coil is room temperature. Typically the condenser coil is warm?
    Problem Solver:
  • 4 Answers
Check to see if the fan is running down in the back by the compressor, if it isn't put a small fan back there blowing on the compressor, also make sure the compressor is running you can unplug it and block the fan by the compressor wait a few minutes and plug it back in so you can hear the compressor to see if it is running. if it hums and then clicks you probably have a bad relay and overload assy.
Posted on Mar 19, 2014
Testimonial: "Sorry I should have put more details in my first post. The bottom fan and all the internal fans are running fine. After my initial posting I found another posting which described the symptoms I was having perfectly. The suggestion was to replace the compressor starter relay and capacitor. I removed my starter relay and disassembled it and found it was full of black carbon. I quite amazed it was passing any current at all. So today's goal is to find a replacement relay locally. Thanks for the follow up. Erik"
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Techsim
  • 59 Answers
SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Posted on Nov 03, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Posted on Feb 08, 2009
lenwest
  • 150 Answers
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
Posted on Mar 26, 2009
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
Freezer not cooling
The clicking you are hearing is probably the compressor trying to run but shuts down after the minute. If your refrigerator has a fan cooling the compressor make sure if is running and the coils are not blocked with lint. A warm compressor is a good sign a hot one is not. The compressor start device or relay could be causing the problem.
Apr 01, 2014 | Refrigerators
Refrigerator won't cool
Unplug for a few hours with doors open to do two things 1 to cool down compressor that got to hot from no fan running and to melt ice off coil in the freezer. There is an internal overload built inside compressor and will stay hot with constant power, thats why you need to unplug. Also check bottom coils where fan is and make sure not blocked with pet hair or debris.
Jan 27, 2018 | Jenn-Air JCD2389G Side by Side...
Freezer is not freezing some items like it should. The compressor is extremely hot and cannot be touched.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 24, 2011 | Frigidaire Freezers
Very hot to touch compressor, is it safe?
Compressors do usually get a bit warm during operation, but unless you left the door open for an extended period, or cooled warm foods in your freezer, the compressor would periodically run, then stop and cool off. If you observe your refrigerator for a while and notice that it is running much more than usual, it may to be serviced, possibly to look for a coolant leak or other similar issue.
May 17, 2011 | Frigidaire Freezers
Freezer freezes and won't cool either freezer or refrigerator.
On my GE side by side (model GSS20IEMDWW), the evaporator coils froze over due to constant running of the compressor. The compressor was constantly running due to a faulty temp sensor in the fresh food side of the unit. The sensor was apparently reading too hot, thus never signalling the computer that it should stop trying to cool.
This could be what the original poster was attempting to describe.
Jul 26, 2009 | Refrigerators
The dividing wall between the freezer compartment and refrigerator compartmant is very hot to the touch , use to be warm now almost to hot to touch. mod. #106.56539400
the condensor fan by the compressor is not running. this fan cools the compressor and condensor coils. if it does not run then the mullion (center between frzr and refrigerator side) gets very hot
Jun 24, 2009 | Refrigerators
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ARB2517CC / ARB2517CB / ARB2517CW Bottom Freezer Refrigerator Logo
117 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
