Question about Sony DSLR-A550 Digital Camera
Sony a550 white balance
Cannot set the custom white balance. I always get an error message unless I use flash to set it.
    Top Expert:
  • Sony Master
  • 6,702 Answers
Do you try to set the white balance, wheel the camera is still in an automatic mode or in a scene mode?, because that won't work. If you keep having problems while in a manual mode, let us know, so I can look again to this problem.
Posted on Mar 21, 2014
  • Clarence Phoenix Mar 22, 2014
    Cannot set Custom WB in AUTO modes. I reset the camera (Reset DefaultT) and it worked, althought the Custom Set was now in the center of the LV screne. It worked with a white sheet of paper and a gray card. Turned off the camera and came back a few minutes later and everything was back where I started - not working. Hmmm.
My tv looks green&can not be adjusted.it is a sony.serial#kds-r50xbr1
Press Menu, Video Custom Settings, adjust Hue to reduce green tone, if that does not solve your problem, go to Advance Video Settings Menu, White Balance, adjust white balance by tweaking R, G, B gain/ bias settings or hit Initial set for factory default settings.
Sep 24, 2009 | Sony Televison & Video
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Best setting for indoor
There are three possible solutions for you:
1. Just use the Daylight (direct sun) white balance setting. Electronic flash is typically close to the direct sunlight setting for white balance. Advantages: it is simple. Disadvantages: if you are balancing electronic flash with ambient light, you are likely to have an odd mixture of lighting, with the ambient lighting tending toward red (if incandescent) or green (if flourescent).
2. Get a Wratten 85 color correction gel that you can cover your flash's head with, and use the Tungsten white balance setting. This will bring your flash output into line with existing incandescent light sources. Advantages: almost as simple as (1), and allows you to come close to matching a common indoor lighting situation. This will produce more natural-looking environmental shots if you balance the flash and incandescent ambient light contributions to the exposure. Disadvantages: large gel filters get expensive. You may be able to obtain something close to the Wratten 85 color correction filter from a theater supply house more cheaply. Roscolux #3408 is slightly weaker and #3411 is slightly stronger than the Wratten 85. If you have to balance flash with flourescent light sources, try a Roscolux in the cyan series leading to #4360. Some experimentation is likely to be required. The place I looked online offered the Roscolux in 20x24" sheets for about $7 per sheet, a bargain compared to the optical-grade Wratten filters.
3. Set a custom white balance. This is not too difficult, and it will definitely provide the best approximation to your desired white balance that you will obtain in the field. Advantages: this will allow you to reproduce white accurately even with mixed lighting sources. Combine with gel over flash of (2) for the very best approach to balanced flash/incandescent lighting situations. Disadvantages: requires a "white" target (can be a neutral gray photo card, for example) and some additional time before a photo session.
You can obtain some striking effects by purposely mixing color temperature light sources. But day in and day out, getting a balanced shot is a skill that it pays to cultivate.
Feb 03, 2009 | Fuji FinePix S2 Pro Digital Camera
Pentax istDS Digital Camera, How to set Custom White Balance in Auto Modes
Custom white balance can only be set in P, Tv, Av, or M modes. The auto modes are, well, automatic. They are all preconfigured and intended for ease of use not configurability.
Nov 08, 2008 | Pentax *ist DS Digital Camera
Setting custom white-balance
F1 or 4 are white balance memories, rather than buttons to set the WB.
Menu > Custom WB > Right Arrow > Select F1 or F4 >
Then put your piece of white card in front of the lense and hit the shutter button. Make sure you haev enough light though !
dave
Jul 26, 2008 | Fuji FinePix S2 Pro Digital Camera
Problems taking photos at night.
Did you use flash? Did you use tripod? Generally speaking night photos with non-DSLR digital camera, W55 is non-DSLR, will be blurry unless either flash is used or a tripod is used. The issue is the camera shutter is set for a long exposure in order to get enough light that it is impossible to hold the camera steady. The color problem you mentioned is most likely your white balance. Normal white balance is sunlight at night you white balance should be Auto, Incandescent or Neon
Jul 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cant switch on off only white screen
ok ur main software form the phone and file sistem does not mach bouth sould be the same in order to work properly who flsh the phone probably flash just the main software bout not the FS go back and told them to completly flash and customize your phone with the same Main and FS
Apr 22, 2008 | Sony Ericsson K800i Cellular Phone
Manual white balance
Click the AF-WB button and then with the wheel in the back of the camera select either K or any of the other settings. If set to K then you must go to your Menu (click menu button on back) then go to Color temp. and select your Kelvin tempature. Hope that helps....
Sep 14, 2005 | Canon EOS-10D Digital Camera
What white balance settings are available?
The following white balance settings are available for the DiMAGE Z3: Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Flash) and Custom.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Should the custom white balance feature be used with or without a flash?
You can use customer white balance with or without a flash. If you use a flash to do a custom WB, you must adjust the F-stop and make it narrower. If you do not do so, the custom WB will over expose every time when using a white card. White balance is used to measure the Kelvin temperature that the light source is outputting so that the camera can set itself to that specific reading.
Aug 29, 2005 | Fuji FinePix S3 Pro Digital Camera
Sony DSLR-A550 Digital Camera Logo
55 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
