Question about KitchenAid Microwave Ovens
Our Kitchenaid KHMS2040 microwave has been making a strange noise recently. It sounds like a shofar or distant trumpet is being blown. As far as I can tell the microwave is cooking just fine, and the noise does not happen every time we use it, but it has been happening Our Kitchenaid KHMS2040 microwave has been making a strange noise recently. It sounds like a shofar or distant trumpet is being blown. As far as I can tell the microwave is cooking just fine, and the noise does not happen every time we use it, but it has been happening more often. often.
    Top Expert:
  • KitchenAid Master
  • 21,522 Answers
Clean the waveguide cover.
Posted on Mar 19, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave problems after HV capacitor replacement???
The rectifier diode could indeed be bad. But first I would want to know what value (in uF) the old one was and what is the value of the new one? If they're too far off, the difference in the capacitive reactance could throw off the "tuning" of the circuit. The uF value of the capacitor is optimized in relation to the other components used in the system. Of course, you'd also want to be sure your new cap is at or slightly above the working voltage rating of the old one, too.
Posted on Jan 05, 2007
  • 43 Answers
SOURCE: Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Posted on Feb 03, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven has become very noisy
Oh, this is a UK/European model...
I have no info on that, so your best bet is to contact Panasonic UK:
http://www.panasonic.co.uk/customer-Support/index.asp
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
  • 112 Answers
SOURCE: Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Posted on Oct 25, 2008
tomsat69
  • 214 Answers
SOURCE: Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
Posted on May 15, 2009
Not heating and making strange noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 26, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Was heating something when it made a zinging noise and now thothing is working no lights or power
My same microwave did this about a week ago... repair people said the part that surrounds a fuse had burned through. 350 to fix it, I am considering just getting a new one since I have now found that mine has had a replacement part fix done after a recall on this microwave. If you have not read the recall info you can find it easily by doing a search for Kitchenaid Microwave recall. There will be a small green square sticker by the serial number if yours had had the recall repair done already. Mine had but I still have had this recent problem even after the recall repair.
May 18, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid microwave makes a loud noise and does not heat
try these
  1. Check timer and clock settings
  2. Reseat the element
  3. Test the element
  4. Test the element connectors
  5. Test the oven temperature control
  6. Test the oven selector control
pls rate my suggestion..
Jul 20, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave makes noise
replace the magnetron it is defective.
Jun 07, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaide Microwave KHMS145KSS rattling noise
there is a possibility that sme of the wireing or the fan has become loose best checking it .
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
My kitchenaid microwave has started making a strange noise when I open and close the door. It sounds like paper or aluminum foil (?) or something is in the door when I close it (moreso than when opening...
Very good.
You may have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove to get at the parts that need to be replaced.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 02, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
SPORADIC HEATING
check highvoltage crcuit ,and check fan, and turntable motor,
Oct 18, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
292 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
