Question about Epson America EPSON WorkForce 435 C11CB45201 Wireless MicroPiezo Inkjet MFC /
Im trying to use a universal ink refiller to fill ink cartridges workforce 435
Where do I inject the ink
Tip
How to Refill the Epson R340's Ink Cartridge
<span>Instructional steps<br /></span> Things You'll Need: <ul> <li> <span>Syringes</span> </li> <li> <span>Refill ink</span> </li> <li> <span>1/16 inch thumb screw</span> </li> <li> <span>Paper towels</span> </li></ul> <ol> <li> Place the cartridge on a flat surface over some paper towels to soak up any spilled ink.<br /></li> <li>Drill a hole directly above the "H" in the word "Push" on the top label.<br /> </li> <li> Drill a hole above the the first hole so air can escape while you are filling the cartridge.<br /> </li> <li> Fill a syringe with the correct color and amount of refill ink. The black cartridge holds 25 ml of ink. Color cartridges hold 10 ml of ink.<br /> </li> <li> Insert the needle of the syringe into the first drilled hole. Slowly inject the ink into the cartridge.<br /> </li> <li> Replace the cartridge into the Epson R340. Allow it to rest for 24 hours so the ink can absorb into the sponge inside the cartridge.please rate this post by saying how helpful it is to you<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_7414161_refill-epson-r340_s-ink-cartridge.html#ixzz13r3MVnYc"><br /></a></span>
on Oct 30, 2010 | Office Equipment & Supplies
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Where do i inject the ink in my cartridges on a lexmark printer. i need to refill both cartridges. i have the black and coloured ink, and the syringe, however i dont know where to inject.
Usually the refill kits come with instructions that cover many cartridges.
A lot of the lexmark's use HP style cartridges and those often you lift the label to access the fill holes.
FILL SLOWLY and do not over fill. Usually the cartriges hold so many ml and youcan measure that on your syringe. Knock off a few ml from what they say the cartridge takes.
Nov 11, 2009 | Lexmark X2500 All-In-One Printer
How to refill hp 818 inkjet cartridge
i have injected 5 ml black ink in my 818 cartridge and inserted in my HP deskjetF2418 printer but it is not working and showing empty signal
Sep 30, 2009 | HP DeskJet F380 All-In-One Printer
How to refill 818 black cartridge
818 blake cartege Error problam not opret my cartege f4200
Aug 27, 2009 | HP DeskJet F380 All-In-One Printer
With WorkForce 500, I am using only black for coping. But other color inks become low and the coping is stopped. Are there any way to do only the black coping?
replace all color cartridges with black toner
if ink fill your color cartridge with black ink using a refill kit
and just buy a new color cart and keep it asside in a zip lock untill you need color
Aug 03, 2009 | Office Equipment & Supplies
How I can refill canon lbp2900b cartridges
Take the cartidge to any refill point he will take 200-300 and fill the cartridge without any damage to the cartridge. He will open the cartidge and refill the same.
Aug 02, 2009 | Canon LASER SHOT LBP-2900 Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Epson America EPSON WorkForce 435 C11CB45201 Wireless MicroPiezo Inkjet MFC / Logo
23 people viewed this question
Top Epson America Office Equipment & Supplies Experts
k24674
Are you an Epson America Office Equipment and Supply Expert? Answer questions, earn points and help others
