Question about Frigidaire GLEF396 Electric Kitchen Range
On my Frididaire Glef396csb, when operating the oven, the light flickers on and off and the power to the oven also goes on and off.
There is a clicking noise as if the door switch doesn't connect.
  • Official Brand Answer
  • 2,267 Answers
Good Morning Cecil,
I see that you are having trouble with the light flickering on and off and also the power going on and off on your Frigidaire range, model# GLEF396CSB. You also stated that there is a clicking noise, as if the door switch is not connecting. There could be a couple of possibilities with these occurences.
First, make sure that you are connected to a 120 volt at a minimum of 40-50 Amp circuit breaker.
Second, there could be something going on with the different control boards miscommunicating.
Third, there could be something going on with the wiring inside the home.
In any case, I would start with resetting your range. You can do this by shutting the power off at the circuit breaker for 2-3 minutes. When you restore the power, you will need to set the clock by pressing the "clock" button, entering in the time, then pressing the "Start" button. Once the clock is set, turn on the oven. If you are still having trouble from there, I would contact either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
Posted on Apr 17, 2014
Recently bought a 99 CR-V. Had it tuned up and fixed almost everything. Runs very smoothly. One remaining problem is engine going dead while driving or just won't start after parking. Dash lights flicker...
Old post.
same here, there is only 2 paths (besides wild $$$ guessing)
1: yes, do scan it, if the tool goes dead (comms down) the ECU lost 12vdc power. (the CEL goes dead to , just key on, if no power to ECU/PCM.
2: or diagnose the no start.
what is flicker?, the dash lights come on key on to tell you power is ok and all things running them thinks they are happy,
some cars have immobilzers, and it does flicker at IMMO mode.
blocking you.
be specific on lights. what lights to what.
the operators guide is free, and shows each light.
Sep 24, 2013 | 1999 Honda CR-V
Hi My light is burned out - how to replace it and during a hurricane we lost power and since then the digital hour continually flickers, the microwave/oven works when I hit what I want to do, but when...
There is a handy step-by-step guide with pictures here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
These use halogen lamps, so you must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Sep 16, 2011 | GE Advantium 120 Convection/Microwave Oven
Recently the light flickers and gets dimmer, then back to normal, several times while heating something in the oven Just wondered if this is some simple thing to take care of, or should we consider...
Sounds like an arcing switch or connection, or maybe the light itself is not making a good connection. Check the plug in the outlet socket to see if it gets hot after heating something. Wiggle the cord to see if the light flickers. The door switch is a microswitch type and should make a positive 'click' when operated.
Feb 05, 2010 | Microwave Ovens
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
I´m having a problem with my wall oven FRIDIDAIRE FEB789WCCG. The front control module where the clock and buttons are have no power, its completely blank. when I push on the buttons nothing happens....
if you can reach inside the oven the fuse almost beside the power terminals usually like cylinderical shape and it has nominal values wroted on it , must be checked continuity at 1st by ohmmeter
thanks
Jul 11, 2009 | Ovens
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Lights occasionaly flicker, panel intermittent
So it's dead, but sometimes the inside lights come on? Does the display come and go, too? If so, and power is getting to the board, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Full information on our service is available at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 20, 2007 | Whirlpool MH7140XF Microwave Oven
Frigidaire GLEF396 Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
