Question about Dell Inspiron B130 Notebook
I want to connect my dell inspiron 1545R laptop with a old model RCA TV 27R411T, My laptop having HDMI port, but my tv have S video and 3 pin RCA (Red, yellow, white) how can I connect it, do I just need HDMI to RCA cable or do I need a converter also?
  • 20 Answers
You will need a converter. try amazon or newegg. they are available but not cheap.
Posted on Mar 19, 2014
  • 3940 Answers
SOURCE: kan vga to laptop and svideo or rca to t.v will it
Here are some options:
http://www.bluejeanscable.com/store/component/vgatocomponent.htm
Posted on Jan 13, 2010
  • 7 Answers
SOURCE: Connecting Dell Inspiron B130 PC Notebook to HDTV
Youll need a regular VGA cord and a 3.5mm to RCA conversion audio cable from Radio Shack like the one below. http://www.radioshack.com/product/index.jsp?productId=2428708
forget going the HDMI route, it isn't worth the money youd have to spend on a converter. once you got your cables hooked up, consult this: http://www.microsoft.com/windowsxp/using/setup/learnmore/northrup_multimon.mspx
Posted on Jul 17, 2009
rockitman187
  • 2559 Answers
SOURCE: funtion F8 not working s video from laptop to TV
Before connecting the external monitor,Shut down your computer,connect the external monitor,Restart the computer and the external monitor should load and The FN+F8 should now work.
Posted on May 21, 2009
bahratt
  • 561 Answers
SOURCE: how connect laptop to t.v. but my laptop only have
You can purchase and try this VGA out to S-Video / RCA cable http://www.amazon.com/VGA-to-S-Video-RCA-Adaptor/dp/B000P3UB24/ref=sr_1_1?ie=UTF8&qid=1263455014&sr=8-1
Posted on Jan 14, 2010
  • 97 Answers
SOURCE: connecting dell mini inspiron with LCD with HDMI cable on both si
You just need a HDMI cable to go from the laptop to the TV. It is refered to as a patch cable. You then go into the TV menu and set it to component or in some cases it will say computer. The VGA on the TV just allows both style interfaces to be connected.
Posted on Jun 21, 2010
Can I attach a HDMI cable to an Old Samsung TV Model # HLN5065W1X/XAA
Gina, these are all the inputs on your TV
S-Video 4-pin DIN (2 sets) Back Composite RCA (2 sets) Back Component 3 RCAs Back Component (HDTV) 3 RCAs (2 sets) Back RGB 15-Pin Dsub Back Tuner Co-ax (2 sets) Back DVI Digital Input 24 pin DVI Back S-Video 4-pin DIN Front Composite RCA Front
You can not use HDMI cable with this set up.
Feb 22, 2016 | Samsung Televison & Video
How do I get external screen on laptop to use on a TV screen?
It really depends on the type of equipment you have. Does your laptop have a HTML port? And does your TV have a HTML port? You can google your Dell laptop on how to make the config settings for displaying on an external monitor (TV) for your particular laptop model. I have done it with the VGA port to an external monitor very easily. The HTML will need some special settings depended on how old your laptop is. Good luck.
May 04, 2015 | Dell LATITUDE Computers & Internet
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
How can i connect my dell inspiron 640m laptop to my sony bravia lcd tv?
Your tv should have vga port. if not you can buy a vga to hdmi adapter
Feb 19, 2012 | Sony Televison & Video
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
How do I connect my dell laptop to my LG LCD TV
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
May 30, 2010 | Dell Latitude E6500 Laptop
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
Connect Laptop HDMI to Receiver to TV via SVIDEO
you need a different type of cable to connect to your tv.a s-video will fit but not work.can't remember the name but it has to have more pins.besides that port is for projectors and cannot be used for anything else.you need a converter box like the one in the link ::::: http://www.bing.com/images/search?q=laptops+s-video+cords&FORM=BIFD#focal=a85da1a40c404788d7e32f0bf01eab05&furl=http%3A%2F%2Fwww.cvs.k12.mi.us%2Ftiz%2Fimages%2Fsvid-cables.jpg
unless you got a big tv with a very good picture it isn't worth it.and a good graphics card in the comp.most tvs are fuzzy and unreadable.i've did it enough to know
Aug 04, 2009 | Dell Inspiron E1705 Notebook
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
Dell Inspiron B130 Notebook Logo
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
