Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
Leibherr fridge freezer makes intermittent buzzing noise
My Fridge freezer makes a 1 second buzzing noise every 5 minutes or so. The repair guy says it is the solenoid magnet controlling airflow and is normal. Doesn't seem right to me. Can anyone help?
  • Thomas Devos
    Thomas Devos Aug 29, 2016
    Hi, I'm experiencing a similar issue with my Liebherr fridge. Did you end up finding out what the problem is? Thanks a lot in advance for any help you can provide.
    Top Expert:
  • Liebherr Master
  • 75,017 Answers
It is quite normal. No problem at all.
Posted on Aug 29, 2016
  • Thomas Devos
    It may not be hazardous but it's definitely annoying. Also, it's something new: there was no such noise for the first three years I had this fridge, so it seems that something broke. At first I thought the sound came from the breaker box because it sounds like a electric malfunction. I also wonder if it could come from the plug.
  • 1462 Answers
SOURCE: My Leibherr fridge/freezer -- fridge
put something flexible down the drain hole from inside the fridge and this will clear the blockage
Posted on Nov 12, 2008
  • 3 Answers
SOURCE: Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Nikunj Pattni
Posted on Nov 17, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
SOURCE: I have a Liebherr fridge freezer. Model n0 CNES
I left the fridge closed for 12 hours after cleaning and the back wall is now frost free.Great!! Lynn
Posted on Sep 09, 2009
  • 17130 Answers
SOURCE: i have a lieebherr fridge
As you had done switch off the fridge. now after the frost had cleared off , keeping the fridge a little away from the wall switch on. But only after you have checked for the thermostat to be set to normal, the fan working fine as well as the timer switching on the auto defrost. So look out for the compressor to shut off when the thermostat reaches the limit, if this wont work then the ocmpressor will run and result in heavy frost. so it can be that the wires to the thermocouple is broken or damages due to frost. so you can open freezer compartment and confirm on inspection of the wiring for any breaks.repeat if frost appears till you correct and confirm. If you are calling a repairman keep this mind so as to get an idea of the work, to have an estimation of the work. Hope you try this out. Good day
Posted on Aug 10, 2010
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
Buzzing noise every 5 to 10 minutes, like an ice machine turning
No ,very possible it is due to expansion. There is a covering on the return pipe called armour flex. this armourflex stops ice migration inside the walls of the fridge. If it breaks away, the ice expands around the pipe and and pushes on the insulation foam which then cracks and makes those loud noises. Have heard this noise many times on a particular brand of fridge to a point where some customers have dived for the floor thinking they are being shot at. Repairing that problem is a biggish repair and not cheap. You will find if it is the compressor it normally only happens at either start up or switch off (a clattering sound)
Sep 19, 2009 | Kenmore 64802 Top Freezer Refrigerator
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
buzzing noise is possibly the compressor tring to restart. It sounds as if the compressor is going into thermal overload. I would suggest the replacement of the compressor. Good Luck
Jul 24, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
New GE profile bottom freezer fridge intermittent buzzing
If the buzzing is a short (say 5 seconds) every once in a while, it sounds like the water is valve being energized. That would mean the icemaker is turned on and is cycling. Besides the noise, when it cycles it turns on the mold heater, which you do not need if not making ice, and thus is actually adding heat to your freezer, increasing operating cost. Just turn the icemaker off by flipping the toggle switch on the icemaker itself. It is a white switch near the bottom corner of the icemaker. Should be easy to spot.
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
257 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
