Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Compressor on GE Refrig Model PFSS5NFW
Wiring diagram for compressor
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Posted on Dec 15, 2007
heatman101
  • 43501 Answers
SOURCE: refrig not cooling and compressor hot short cycling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ghddgkh
Posted on Sep 29, 2010
I have a hss25ifmdww thats not cooling the compressor is not coming on how can i check to see if its a bad control board or compressor
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire1 , and the other into wire3 . Plug the refrig back in and see if the compressor now runs . If it does , replace the board . If not , compressor is bad . When testing , ONLY the compressor will run and nothing else will .
Jan 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Oct 11, 2007 | GE PSI23MGN Side by Side Refrigerator
Hello I have a GE lower freezer model # PDS22SBSARSS AND THE TEMP CONTROL is clicking and the digital readout is doing weird things by indicating wrong temperature and clicking, it stops after awhile...
Roll the refrig out and determine where the clicking noise is comming from. If it is form the small rectangular cover on back, replace the main board (WR55X10942) located under it. If the clicking is comming from the compressor area (at the very bottom, behind the cover which goes all the way across the bottom of the refrig) then replace the relay (WR07X10086) and overload (WR08X10061) located where the wires attach to the compressor, and for good measure, the capacitor (WR62X79 ). (located just to the left of the compressor)
Jan 12, 2011 | GE Profile PDS22MHR Bottom Freezer...
Compressor won't work. the fan runs but not the compressor
Well, unfortunately you will have to replace the compressor.
you might as well replace the refrigerator for a brand new one since replacinng the compressor isn't economical.
As an appliance repair ny company we handle this issues frequently and replacing the compressor would cost you over $400
Hope it helped.
Oct 17, 2010 | GE Refrigerators
On my GE refrigerator is not getting cold at all in the refrig nor the freezer. When I open the door the light is on and the fan is running. Is there an enteral fuise?
The compressor relay is bad on the main control board . Unplug the refrig and pull the refrig out and remove the 8X10 small panel on the back . You will see a blue plug with 3 larger (120v) wires going to it . Remove this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . (this is on the plug NOT the board ) . Using a short piece of insulated wire , with about 1/4" stripped off both ends , insert 1 end into wire1 and the other into wire3 . Plug the refrig back in . This will start the compressor to verify the main control board is bad . Pt # WR55X10942 .
Aug 19, 2010 | GE PSS25SGNBS Side by Side Refrigerator
Need wiring diagram for GE model CA15DRN upright freezer-compressor relay busted & not sure which wires go to which terminal on compressor.
http://genet.geappliances.com/DocSearch/pdf/49-6545.PDF
The best I could come up with is this site for the user manual. Not able to find wiring diagram on this GE site. Hope this helps ya.
Nov 24, 2009 | Freezers
GE Model GSS25TGNB CC died
If you do not see frost on the inside rear wall of the freezer , Poll the refrig out from the wall , and remove the back panel covering the compressor . If the compressor is not running , Remove the 8" X 10 " panel , just above the large panel first removed . Unplug the refrig . Remove the control board , and on the other side of the board ( soldered side ) , look just behind the small black boxes ( located on the other side ) and look for a joint which has become unsoldered . Resolder this spot and reinstall the board . Plug the refrig back in , and see if compressor starts . OR , you can replace the control board pt # WR55X10656 .
Sep 19, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer not staying cold and compressor not cycling and overheating
if compressor going off on overload. you could have a defective compressor relay or compressor.
relay part# WR07X10025 cost aprx. 20.00
also be careful before buying parts b/c your model comes w/ a main pc brd that gives 98% of problems on ge refrig.
Jul 16, 2009 | GE GSS20IEP Side by Side Refrigerator
Wiring hard start capacitor in GE refrig
I would go back to person who gave that advice because just the right touch on that capacitor and YOU my friend will be in the hospital. If this is helpful, please post as such. TY
Jan 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrig lights go on and off intermittently when opening and closing refrig door
check door light switch with ohmmeter. Check for melted insulation near light "terminator". Look for wiring diagram in ziplock behind compressor grille. Second switch at door turns compressor off when door opened. I had these problems with a 695 which I would assume is probably similar in design.
Dec 26, 2007 | Sub-Zero 680 / F
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
