Question about Solo 654 Chainsaw Vintage Collectable Saw German Saw
It wont stay running after i get it started
I can chocke it a little bet and keep it running that way but i cant get it to idle
    Scholar:
  • 136 Answers
That means that it is not getting enough fuel to the carb. Check your tank for fuel and the hose and filter inside. Make sure all the hoses are attached right and are not broken or leaking.
Also close the adjustment carb screws all the way in. Then open them one turn back to start . Try to start the saw. Then make adjustments to the low adjustment screw. If any of these don't work try a known working carburetor. See if that makes a difference.
Posted on Mar 19, 2014
Car starts and runs for bout 20 sec then dies starts right back up but wont stay running
Try spraying some starting fluid or carburetor cleaner into the engine an see if it will keep running ! Have you tried holding the throttle open a little or are you just letting it idle ? Any lights lit on dash , check engine ?
Mar 23, 2015 | 1997 Buick Skylark
1994 ford ranger 2.3 runs fine wont stay idling
Try TPS. Throttle positioning Sensor. This sets base idle. (Unless this model is too old for that sensor)
Sep 21, 2014 | 1994 Ford Ranger Supercab
Will start with chock on but wont stay running with it off
the idle jet or the float valve is blocked
you need to strip the carb and unscrew the jets and clean them
i use small interdental brushes ...
Mar 23, 2014 | Stihl Blower Handle Moulding Bg Sh 45 55...
It takes to lot start it wont stay running if i have the chock out part way out it will run but it needs head gasket could it be that
If it needs a head gasket, what else is wrong.? It won't run right at all without the proper back pressure, Is it water cooled? Also sounds like the slow speed jets are clogged, did it sit for a while? Need to check that out, those things have to be spotless, or it won't idle or start. Hope this helps.
Feb 27, 2011 | 1981 Suzuki GS 750 L
When i start my jeep in the cold mornings it starts up but bogs right down and stalls then i have to accelerate for the second start up for a few minutes to warm it up a little and then it bogs and stays...
Your only problem friend, is the temperature sending unit/sensor. Upon cold start, this sensor wil tell the computer to go into cold start mode putting a bit more fuel in and raising the idle a bit to keep it running when cold without using the throttle. Replace that sensor and your good to go. Makes sense, right?
Dec 07, 2017 | 2000 Jeep Grand Cherokee
Runs great at hwy speed pops and slow response when you stop
Sounds like a lean condition. Adjust the carburator for a richer idle mixture.
Apr 11, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
Snow blower wont start
carb is probably gummed up from old fuel..take it off then clean it good and i bet it fires up
Feb 05, 2010 | RTO Sno Wovel wheeled snow shovel
My 88 dakota will not stay on!
it sounds like the new idle you put in is set too low so the truck is getting barely enough gas to start and keep running try turning up the air fuel mixture and it should be better hope this helped
Apr 09, 2009 | 1988 Dodge Dakota
I cant remember what I had replaced about 5-6 months ago, seems like it was a sensor. My 1993 Ford Explorer is not running or idling at normal speed. When I pull up to stop it is like it stays engaged and...
listen for a hissing noise(vacuum leak around the pcv elbows or upper intake gaskets) this will cause a high idle set off lean codes which will say bad o2 sensors alson check idle air control valve which is located by throtlle body this will stick causing the vehichle to not run at idle sometimes taking it off and cleaning the carbon buildup out will fix the problem use some break cleaner
Feb 23, 2009 | 1993 Ford Explorer Limited
I have a 1988 GMC Sierra 1500 that wont stay running
fuel pump,fuel pressure regulator, or vaccume leak,
may also need complete tuneup,or as a last shot the timing gear could be a tooth off
Feb 21, 2009 | 1988 GMC C1500
Solo 654 Chainsaw Vintage Collectable Saw German Saw Logo
115 people viewed this question
Top Solo Garden Experts
Jim Parker
Jim Parker
Colin Stickland
Colin Stickland
Are you a Solo Garden Expert? Answer questions, earn points and help others
