Alps MD 1300 Thermal Printer Logo
D
Dave Poolsawat Posted on Mar 19, 2014
How to read test page for Alps printer
Anyone know how to read the test print page to determine the band count on Alps MD 5500?
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Mar 19, 2008
SOURCE: Do you repair Alps MD 5000 printer
Unfortunately, this website is not a repair shop, but I'll give you what help I can....
Printhead problems are not repairable in the US or Europe any longer. You best bet is to upgrade to an MD-5500, which you can find here: http://www.alps-supplies.com
Anonymous
  • 58 Answers
  • Posted on Mar 20, 2008
SOURCE: Alps md 1300 only prints in black
First of all, Alps MD inks do not "Dry up". They are dry to start with!
It sounds like you may be running XP, with the Microsoft driver for this printer installed. You need to load the Alps driver, which you can get by joining the alps or alpsdecal group at http://groups.yahoo.com. You can find the driver in the files section of one of the groups.
Anonymous
  • 58 Answers
  • Posted on Mar 21, 2008
SOURCE: lines through my md 1300 alps printer
It sounds like the head has been damaged. Unfortunately, there is no fix for this, as Alps stopped production of these printers years ago, and now do not offer repairs for these printers.
If you still want a dye-sub capable Alps printer, the only model available is the MD-5500, which you can find here: http://www.alps-supplies.com
Anonymous
  • 58 Answers
  • Posted on May 24, 2008
SOURCE: Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Anonymous
  • 155 Answers
  • Posted on Feb 06, 2009
SOURCE: Button sequence for head test (to look for banding)
Turn the printer off.
Load a sheet of white laser paper.
Press and hold the "Power" & "Ready/FF" buttons at the same time.
Release the "Power" button, and keep pressing the Ready/FF" button.
Right after you release the "Power" button, count 4 seconds, and release the Ready/FF" button.
Immediately, press and release the "Ready/FF" button one last time.
The printer should start printing a series of letters, numbers, horizontal lines and a black solid bar at the bottom of the sheet.
Once this test page is completed, turn the printer off to stop the test.
ALPS MD-5500 banding problem
Greetings from Mississauga!
Repairers
https://www.google.com/search?q=ALPS+MD-5500+repairs+canada
Banding appears to be a known issue. Have you heard of the Dye Sub Upgrade? I have no idea what that means, but it says it fixes the issue
https://www.dpreview.com/forums/thread/10147
More here
https://www.google.com/search?q=alps+md-5500+banding+problem
1helpful
Is 4330 band printed quite a few
That is a low band printed count for any ALPS printer.
2helpful
Is there a way to determine the number of pages an Alps MD-1000 has printed, like a mileage gauge on a car.
Yes. It's very easy. Turn the printer off, unplug it, and disconnect the printer cable. Insert two sheets of paper, and make sure the paper feed is set to automatic. You need to have a black cartridge loaded into the 1st slot.
Plug in the printer and wait for the lights to turn off. Press and hold the power button at the same time press and hold the "ready/Insert" button. Release the power button, but keep holding the "ready/Insert" button for at least 4 seconds. After 4 seconds, release the "ready/Insert" button and quickly press it again. The printer will start the selftest.
For the 1300, the number of bands printed will be on page two. On the 1st page, there will be a black bar on the bottom of the page. It should be a solid black bar with no lines - this is the test for bad elements on the print head.
I'am trying to print a decal on am alps 5500
You could try using spot colors for each layer of the decal. This gives you the highest resolution.
Cleaning an Alps MD1300 print head
Use a cotton swab and alcohol and gently rub the print head element.
Problem Printing with Alps MD-1000
Have you ininstall the device and reinstall it? Do you have any pending print job?
1helpful
2answers
Lines through my md 1300 alps printer
2answers
Alps md1300 lines through ink
Top Alps Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
ADMIN Andrew
ADMIN Andrew
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
