Question about Cat Pump Pressure Washer Pump - 4 GPM, 4000 PSI, Model 66DX40GG1
Oil appears to have come out of the oil filler cap. Is this a sign of overfilling the oil, or something else?
Someone else filled the unit with oil prior to me running it for about 10 minutes.
Id definitley say its over filled. try checking the dipstick
Posted on Mar 19, 2014
Leaking oil from the top of the cap...
Oil cap leaking - Harley Davidson Forums
www.hdforums.com/forum/sportster.../550364-oil-cap-leaking.html
Aug 13, 2010 - There is always a big amout of oil at the bottom of the bike (probably all from oil cap) and it's drippin' all the time especially if bike is hot. 2007 sportster 883 leaking oil
May 31, 2009
Sportster Oil Leak
Oct 3, 2006
More results from www.hdforums.com
Oil leak at filler cap - Stromtrooper Forum : Suzuki V-Strom ...
www.stromtrooper.com/v-strom-service.../78495-oil-leak-filler-cap.html
Aug 24, 2012 - but more so it seems to me that a new bike shouldn't be leaking oil at all. ... Do I just need to have the dealer replace the seal on the filler cap?
Harley Davidson Motorcycles : About Slobbering Oil ...
? 2:20
https://www.youtube.com/watch?v=lB2DpvxKTGw
Dec 1, 2008 - Uploaded by expertvillage
Jan 20, 2016 | Motorcycles
Tip
Where are located oil plugs for AUDI tiptronic automatic gearbox
At the bottom of the automatic gearbox (tiptronic) you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up. Tightening torque is 24 Nm.
Automatic Transmission Fluid (ATF) checking:
1. Requirements for check:
1.1. Vehicle standing on level surface.
1.2. Transmission must not be in fail-safe mode.
1.3. Shift lever in "P" position, parking brake applied.
1.4. Engine idling.
1.5. Air Conditioner and heater OFF.
1.6. ATF temperature must not exceed 104 Fahrenheit degree (40 Celsius degree) at start of test.
1.7. Only ATF with designation ESSO LT 71 141 may be used. Do not use any lubricant additives.
1.8. Automatic Transmission Fluid ATF - part number: G 052 162 A2 (1 liter wrapping)
1.9. An ATF level check when transmission oil temperature is too low results in overfilling, when too high results in underfilling.
2. CAUTION: Too much or too little ATF will affect the operation of the transmission. The ATF level must be checked at regular intervals.
3. The oil level is correct if a slight amount of oil runs out when ATF temperature is between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg) (caused by increase of oil level when heated). For warmer climates, 122 F deg (50 C deg).
4. Hang filled ATF reservoir VAG 1924 as high as possible.
5. Shift lever in "P" position, engine running at idle.
6. Place oil drip pan under transmission oil pan.
7. Remove ATF filler plug (at the bottom of the automatic gearbox you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up.
8. With ATF temperature between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg), for warmer climates, 122 F deg (50 C deg), a slight amount of oil will flow from filler hole when ATF level is correct.
9. If necessary drain or top off ATF to attain correct oil level. Top ATF with filler hook from VAG 1924 ATF reservoir. Insert VAG 1924 (tool) ATF reservoir filler hook into filler hole and top off until a slight amount of oil flows from filler hole.
NOTE: Fit filler hook into one of the oil deflector cap slots placed on the filler opening.
CAUTION: Do not press filler hook upward or oil deflector cap can be pushed off.
10. Reinstall ATF filler plug. Tightening torque is 24 Nm.
on Dec 19, 2009 | Audi A4 Cars & Trucks
I buy air compressor but how I put the oil
Of course, if this came with a manual.....it should clearly indicate the fill orifice. If it is like the one pictured, The end opposite the handle, where the metal end of the pump is exposed on top of the tank, has a filler hole with a filler cap pushed or threaded into it. Twist this off and add the oil until you see it rise to the half-way point on the sight glass. On brand new units, the filler cap will be taped with a small caution tag, warning you not to start the unit without first adding oil. Most units use a high performance, non-foaming, full synthetic 20-50w oil. If there is no sight glass, the filler cap will have a fill level indicator. Do not overfill!
Oct 21, 2012 | Tool Shop 6 Gallon Air Compressor
How many amount of atf fluid to be filled with my 2001 audi a4 1.8L non turbo?
How to check & change oil in automatic transmission on 2001 Audi A4 1.8L
At the bottom of the automatic gearbox (Tiptronic) you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up. Tightening torque is 24 Nm for drain plug, respective 80 Nm for filler plug.
1.4. Engine idling.
10. Reinstall ATF filler plug. Tightening torque is 80 Nm.
Sep 20, 2011 | 2001 Audi A4
FILLING OF TRANSMISION OIL
1.4. Engine idling.
Jun 01, 2011 | 2006 Audi A4
I need to put motor oil in my car and dont know how to so it cause my eletric to stop and i also need my breaks fix
First problem: adding motor oil. Open the hood of the car, there is usually a lever or handle with a picture of the hood on it, pull that to open hood. Find OIL FILLER CAP and remove. Find the Oil Dipstick and check oil level FIRST! Do not overfill engine oil. Open container of oil and pour in to oil fill hole. The dipstick will have marks on it to let you know where the FULL LEVEL is, do not overfill. Electric should return once engine has sufficient oil in it. For brake problems, please bring your car to the nearest brake shop.
Hope this helps.
Feb 10, 2011 | 2001 Mercedes-Benz CL-Class
Wondering how to check fluid levals in transmission? i have what appears to be gear oil leaking from gearbox connected to half shaft on right side.
1.4. Engine idling.
Please do rate my response. Thanks!
Dec 21, 2010 | Audi A6 Cars & Trucks
I want to know the point to re-fill gear oil in my car
How to check & re-fill gear oil in automatic transmission on 1996 Audi A4:
1.4. Engine idling.
Dec 01, 2010 | 1996 Audi A4
Checking transmission oil 2003 audi a6 tdi auto
1.4. Engine idling.
Oct 16, 2010 | 2000 Audi A6
How to locate the transmission fluid filler screw ?
1.4. Engine idling.
Aug 17, 2010 | 1999 Audi A4
Cat Pump Pressure Washer Pump - 4 GPM, 4000 PSI, Model 66DX40GG1 Logo
110 people viewed this question
Top Cat Pump Garden Experts
Jay Finke
Jay Finke
ray012965
jeff chenault
jeff chenault
Are you a Cat Pump Garden Expert? Answer questions, earn points and help others
