Question about Radio Communications
Midland lxt380 I have two radios. They both worked purfectly. After not using them for about 2 years voice signals are not transmitted/heard Both devices are functioning as it was from the start, except doing the main task - I cannot hear anything that is said from other device and vice versa. One device gives system all sounds (as it ritten in a manual, like ones for Call, TX, Rb etc) in full sound, but other one gives those sounds in very week volume (barely heard). Both devices are tuned to the same channel, settings are equal (silent mode is turned off), batteries are checked and fully charged. What can cause the problem and how to fit it? Thanks!
    Novelist:
  • 103 Answers
Hope this helps... try swapping battery pack and antenna. Try also all available channels path... Goodluck.
Posted on Mar 19, 2014
Testimonial: "Thank you, Mr.Rosener. I tried swapping and different channels - the same - no voice transmittion, and one of radios is almost silent as for system sounds.."
  • 2 more comments
  • Rosener Guyano
    Rosener Guyano Mar 21, 2014
    Your welcome. Wish it is under warranty or even offer extended services. We've encounter the same problem though different brand and twas out of warranty. What we did, we opened and adjust the surface mounted variable potentiometer while other units having burnt diode in the receiver section.
  • Vitaliy
    Vitaliy Mar 22, 2014
    Unfortunately, it is out of warranty already..
  • Vitaliy
    So you have managed to work your radio by adjusting the surface mounted variable potentiometer and changing burnt diode?
  • Rosener Guyano
    Rosener Guyano Mar 24, 2014
    Yes it works both. Though we find difficulty in replacing the burnt diode due to availability the fact the replacement was extracted from other digital devices like harddisk. It sounds tricky but weve accomplished by trial. Thanks.
AngellXP
  • 27 Answers
SOURCE: One radio doesn't transmit voice
I think there defective. I'd return them.
Posted on Nov 15, 2007
ryanriopel28
  • 130 Answers
SOURCE: Midland 70-340A 2 ways VHF RAdio
It sounds like interference.. I wouldn't worry about it too much.
Posted on Dec 22, 2007
eradiostore
  • 1654 Answers
SOURCE: won't receive or transmit
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Posted on Aug 21, 2008
SOURCE: SL55 Not Transmitting/Recieving
the two radios are on different CTCSS Tones
Posted on Nov 22, 2008
eradiostore
  • 1654 Answers
SOURCE: Lost manual - can only get one T3 radio to transmit
http://www.motorola.com/mdirect/manuals/fv200_userguide.pdf
Check your Interference Eliminator Code.
Posted on Dec 10, 2008
Midland 1001lwx does not transmit any solution
take the little switch on the front and flick it to CB , turn up the mic gain and have at it.
Feb 16, 2013 | Midland 1001LWX CB Radio
Hi, I have a LXT380/385. I find out haw to turn
I had the same issue here is the quote from the owners manual: To increase/decrease the volume level, press the up or down button during RX or STANDBY mode. With both radios on the same channel hold down the transmit or "PTT" button--this will put the other radio in the RX mode. While holding down this PTT or side button on one radio then you can adjust the volume on the other radio using the up or down arrows. (This is how you do it on RX mode. I'm not sure yet how to enter Standby mode.)
Oct 30, 2010 | Midland LXT365VP3 Two Way Radio
Will not get good recepiton.
Hi stormnorm157,
Much of the time this is caused by problems in the antenna system. Make sure there are no shorted or open connections in the coax or PL-259 connectors. Use your radio's meter or better still, a Power/SWR meter to check the SWR of the antenna. Try to get that as close as possible to a 1:1 ratio on the meter. A shorted or open antenna can keep the audio receive on your radio at very low levels. Plus, this will harm your transmitter if you continue keying the mike.
Another problem can be in the radio itself. This will be noticed if you can transmit, but have no "Modulation". Modulation can be described as the voice heard above the "Carrier" (your transmitted signal). Every CBer knows about the term, Modulation. The Truckers will definitely inform you about your modulation quality...lol. This problem can be due to a defective AMC (Automatic Modulation Control) stage in the receiver circuit. And, there will be no modulation upon transmit.
One other thing could be causing this lack of receive. Defective wiring or switching in the microphone can result in no audio. Or, in many radios, a missing mike will not allow receive, because the mike connection completes the RX (Receive) circuit.
Solutions:
1. Check the antenna system, and rule that out or fix.
2. Check mike, or substitute another one.
3. Using meter, and or another radio for listening on same channel, check power and receive.
4. You can probably fix 1 and 2 yourself, or with a friend.
5. AMC problem in radio (as described above) will require professional service.
Let me know how this turns out, and inform me if I can offer any more help. Thanks.
Regards, Bill
Sep 18, 2010 | Midland 1001Z 40-Channels Base CB Radio
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
One radio continually transmits
Hello
This could be the Ptt Switch , Midland is 3 Years warranty try to claim the warranty, this is a Factory fault.
Oct 25, 2007 | Midland LXT303-A 2-Way Radio
How do you unlock the channel?
Press and hold the Lock key for 5 or 10 seconds until a beep sound is heard.
Good luck
Oct 23, 2007 | Midland M222P (22 Channels) 2-Way Radio
Radio Communications Logo
55 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
