Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
Asemble shrdder wouldlike to see a vdio on hw o assemble shedder
  • KitchenAid Master
  • 1,267 Answers
Https://www.youtube.com/watch?v=p3Pm4wLYoS8
https://www.youtube.com/results?search_query=Kitchen%20Aid%20Shredder&sm=12
Posted on Mar 19, 2014
Hobart mixer
hi Gassman, below you will be able to find a link on parts assembly for the mixer, you will have an idea on how to tear off the parts, get them cleaned and place them back, like a regular maintenance.
Hobart A200 Mixer Parts Assembly
More parts assembly for Hobart A200 Mixer
hope this helps.
Aug 19, 2008 | Hobart A200 Stand Mixer
My blade assembly broke. Can I get a new one for my Maxi 4000
replacement can be found on amazon, take a look here: Amazon com Vitamix blade assembly. I hope this was helpful. Cheers
Jan 16, 2013 | Vitamix Vita Mix Maxi 4000 Commercial...
I can hear the motor running, but the attachment does not move.
Sounds like what happened to my wife's mixer. There is one nylon gear in the drive assembly that is designed to break if too much load is put on the mixer. Like what can happen with dough or butter that is too hard/frozen. That is designed to save rest of the mixer. Sounds like you need to replace the KitchenAid Mixer Worm Drive and Pinion Gear Assembly. In our case, it was not the nylon gear that broke, but a small pin that is this gear assembly. By getting the assembly & not just the nylon gear, you cover more of your bases. I found a video on line that walks you through replacing the part. I also bought the part online. The assembly part, including shipping cost me $12.95.
Hope this helps.
Nov 30, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at Kitchenaid.com
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
Model mp2671 6 quart only has one speed (fast) it runs for a minute and then stops on its own.
SWANN1001 - Based on your mixer?s symptoms, my first thought is that your mixer?s internal controller assembly (the speed knob), has gone bad. The inspection and troubleshooting of the control assembly is something you can do yourself, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in this case, KP26M1, and then select one of the files that appear under Parts List file. Turn to page 4, Case, Gearing and Planetary Assembly and locate Illus. #8, Control Assembly. This is what you?re looking for when you get the top (Illus. #1) off the mixer head. First check to see if any of the connections have come loose. If everything looks tight then you need to replace it. Unfortunately the whole controller assembly is on a little PC board filled with resistors, capacitors and diodes, which was not meant to be 'home fixed'. Also, my 'expertise' ends at being able to recognize a resistor from a capacitor, but I don't get much deeper than that. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not. Or foregoing the testing of the control assembly you can order and replace it yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part may vary widely between vendors, so do your comparison shopping. I hope this helps! Howard, Burke, VA If this solution has helped you, please rate it. hslincoln
Nov 24, 2009 | KitchenAid Food Mixers
Trying to find what the shaft assembly looks like on a Hobart H600 Mixer
b1sam - You might try using the very easy "Hobart" smartparts webapp on the Hobart website. Cut and paste this into your browser Address line: http://catserv1.itwfeg.com/Hobart-Root/assynode.cfm From there you can select from 19 assemblies to review. Each assembly includes a parts list and an exploded view of the assembly. Based on your comment 'shaft assembly', I believe you want to look at either #12, Transmission Unit or #13, Planetary Unit.
Good Luck... I hope this is helpful.
Howard, Burke, VA
Nov 19, 2009 | Hobart H600 Stand Mixer
No power
ambpsg143, Sorry to hear you don't have power. I'm assuming the outlet you're using works and you've already checked your breaker box to make sure the circuit breaker hasn't tripped (or blown a fuse if you still have a fuse box). If all that checks out OK, then it is definitely a power issue inside the mixer, which means it a couple of things could be conspiring against you. My first thought is that It may be a bad controller assembly (the speed knob), or it could be the motor, but either way it's something you can check yourself. I'd start with the controller assembly and inspect that first. It's possible a connection has come loose. Unfortunately the whole controller assembly is on a little PC board filled with resistors, capacitors and diodes, which was not meant to be 'home fixed'. My 'expertise' ends at being able to recognize a resistor from a capacitor, but I don't get much deeper than that. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not. The next possibility would be with the motor itself, but electric motors are pretty simple mechanisms and generally don't fail, so my bet's with the controller assembly. I hope this helps. Howard, Burke, VA
Nov 04, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Can't take apart the body on the mixer
from what i can see you need to remove the mixer head assemble which has a retainer that i havent been able to remove from mine as yet. need a special retainer pliers and you need to remove the rear stand asemble. i have not figured that out yet either. there are no screws under the logo plate. and the screws on the body only loosen the inner assembles, motor and such. this is a tough nut to crack. mine overheats kneading bread and i want to ad a fan.
Jan 04, 2009 | Hamilton Beach 63221 Stand Mixer
Kitchenaid Stand Mixer - gear assembly coming loose
There should be screws to tighten. Or maybe the pin holding the gearhead on is missing, tho that is unlikely.
Jan 21, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
