Question about Intel Computers & Internet
Cant get the disk compartment to open
Its a new laptop and I cant get the disk to open
  • 31 Answers
If you have a disk inside, get a paper clip and straighten it. Locate a tiny hole on the "door" usually next to eject button. Poke the paper clip in gently and push when you feel resistance. Remove your disk and claim warranty from your supplier
Posted on Mar 19, 2014
I need to open my asus laptop but i cant remember
If you still have the windows installation disk, you can reset it, and set up a new password. Follow the instructions here: How do reset my windows 7 home basic administrator password without...
Hope this helps!! Good luck!
Oct 13, 2014 | Computers & Internet
Reseat hard drive
The hard drive can be removed and reconnected (reseating) by removing the screw/s on the bottom of the laptop. The hard drive compartment will have disk symbol. Open the laptop lid slightly before you slide out the hard drive. Insert the hard drive back into the laptop so it makes proper connection.replace the screw/s.
Boot up the laptop, if it does not boot up then power off and power up and press F1 to go into IBM BIOS setup - check to see if the hard disk is detected. If not then the hard disk is faulty and needs to be replaced then Windows needs to be installed on the new hard disk to get the laptop operating again.
May 30, 2012 | IBM Thinkpad T43/p Notebook
Cant get past the start window
The main problem is the hard disk switch off the laptop and remove the battery from its compartment then remove the hardisk cover and remove the hard disk from its compartment now replace the cover and insert the battery to its compartment and switch on your laptop and see wether the system show boot error if you can see the boot error and when you connect the hard you doesnt go till there it means you have a problem with the hard disk
Dec 30, 2011 | Sylvania G-Netbook
I have del all of my acer aspire one disk partitions and now i cant' create a new partition it show no hard drive. I Cant repair it with win7 setup disk it show no disk drive.... i can found c: drive...
Right click on My Computer, then click on Manage. A new window will open. In that window there is menu on left side pane. In that menu, find Disk Management and click on it. Now you see your hard disk along its partitions. Right click on any unpartitioned and select create partition. Now enter the drive letter and the amount of memory you want to allocate. Hope this helps you!!!
Aug 16, 2011 | Computers & Internet
Cant open my laptop "bootmgr
It looks like you are going to use those recovery disk you were suppose to make when you got the computer. I refer you to http://social.technet.microsoft.com/Forums/en/itprovistasetup/thread/e6b22272-3849-4625-a218-a9d49031f73c that has a write up on recovery.
Dec 22, 2010 | Dell Inspiron 1525 Laptop
Hello dear experts the hard disk of my toshiba tecra m1 laptop was damaged and i bought new hard disk to replace it but it wont detect the new hard disk in the bios the new hard drive model is : western...
All IDE hard drives are cross compatable. I would think you have eaither bent a pin inside the carriage compartment or your IDE adapter is either not pushed on the new HD good or is bad.
Sep 19, 2010 | Toshiba Tecra M1 PC Laptops
Suddenly the computer and all the programs froze and it does not restart, I always a black screen with a mse telling me to reboot the computer or to insert the hard drive device to reboot... I insert the...
note yet..............the hard disk is the problem.
did you by mistake drop the laptop or someone did. It may have sloted out of place and sometimes makes it not function well. sometimes a little tap at the disk compartement side could solve a shifted disk which can be the case here or try opening the hard disk compartment with the appropiate screw drivee, remove the disk and reinsert it again and make sure it fits firmly. if you are within warranty period do return it to be atttended to by a technician or counsult a local technician for help.
good luck.
Jul 04, 2010 | ASUS N61Jq A1 Notebook
I cant open any of the drives C,K displays an error message: no disk
Hi!
   Try to reboot your computer. If still you cant open it after rebooting. Click my computer icon. using right click then select disk management then try to see the condition if your drives are present. If its present but it is not found in the display you try to check your Hard disk drive to another computer and scan for viruses.
jonags
Jan 22, 2010 | Acer Aspire 3680 Laptop
Winload.exe
Hi there.
When you turn the laptop on, keep pressing Alt+F10. This should open the recovery program. Follow the on-screen instructions for factory settings.
Let me know if this does/doesn't work.
Tim
Apr 19, 2009 | Acer Aspire 3680 Laptop
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
