Question about Numark Industries Numark NDX400 Tabletop Scratch MP3/CD Player With USB
How to get laptop to read usb cable connection to the numark ndx400
When connecting the laptop via usb cable to the numark ndx400 the player does not read the usb connection
2 Suggested Answers
SOURCE: my numark ndx400 usb slot
do a folder with just 10-12 tracks in it.
Posted on May 23, 2011
Can i connect a numark NDX400 to my sony surround sound its a s master amp?
Yes, you should use CD inputs and should work like a champ, hope it helps..
Oct 16, 2013 | Numark Industries Numark NDX400 Tabletop...
Numark ndx400
1 of yor tak switchs are faulty either cue or play button or maybe even the scratch button replace all 3 that should solve
Aug 03, 2013 | Music
My numark NDX400 is acting strange. When i am
i did have same problem,i sale them in secend hand shope,not trsutfull ndx400 to be honest.after that i buye new numark mix express.that better than ndx400
Aug 03, 2013 | Numark Industries Numark NDX400 Tabletop...
When pressing the cue button on ndx400 all functions gets activated
did u fix this issue im havin the same trouble could u email me with a solution if u have 1 that wud be good my email is stuartsharratt@yahoo.co.uk
Dec 12, 2012 | Numark Industries Numark NDX400 Tabletop...
Numark NDX400 will not play a flash drive with more than 1 track loaded on it
I had exactly the same problem. You need to press the "Track Push" knob when you have selected the track you want you can then hit "play" to play the track.
Dec 08, 2012 | Numark Industries Numark NDX400 Tabletop...
Distortion troubles with numark ndx400's
The bad news is it could be any of them. or it could be the lighting- CFL's and regular flourescent lighting are bad for audio, as are switching supplies used in TV's, microwave ovens and some musical gear. They are worse than lighting dimmers for noise.
The thing to do is start at the speaker itself and work through the chain of devices to find the one distorting. An old transistor radio is useful here. Most actually do have enough power to faintly drive a large speaker- listen for scraping and rattling- it would mean the voice coil windings may have come loose or the coil form is damaged from heat.
Move back to the amp input and try again- this time listen for a clipped sound if the speaker checked out okay. It would sound like the Charlie Brown adults in the cartoons. That would be a failure of an active component in the amp. If you now hear rattling or scraping- the speaker voice coil is bad and should be repaired or replaced.
If it sounds good, move back to each deck. apply your radio- volume turned down to an input it one is provided. Each should sound clean like the amp did. If no sound or distorted sound is found here- which is the most probable location, it is likely one of the IC chips is at fault. Likely a 4558 if an IC fault, otherwise suspect dirt or hair on the encoder connected to the spin platters.
Mar 30, 2012 | Numark Industries Numark NDX400 Tabletop...
A cd is stuck inside my numark nd400 tabletop scratch cd player
Only safe way is to take covers off to get to the player. A common problem is jamming by a label that came off OR the little belt that drives the carriage has deteriorated or failed. Only way in either case is to open the unit.
Jul 11, 2011 | Numark Industries Numark NDX400 Tabletop...
My NDX400's display screen doesn't show anything. When I turn it on, all the "characters" flash white, so I know it works. But then, it just goes blank. No matter what I do, nothing shows...
If you was to turn the deck upside down you will see 4 main screws in the corners holding the silver top to the black chassis of the deck. undo these screws and carefully turn the deck over and lift the top off slowly. I say slowly because before putting it down (you might need someone to hold it for you) you need to un-clip the white plug and there will be a data ribbon stopping you from pulling the lid away. this is the strip you need to check both ends that the connections are clean and pushed in properly (the blue strip on the connector should be facing the middle of the circuit board) be careful not to snap the connector and make sure you push it into its socket straight and not at all at an angle or it could snap. put the white connector back in and pop the lid back on and turn it on to see if worked.
Jul 05, 2011 | Numark Industries Numark NDX400 Tabletop...
Numark Industries Numark NDX400 Tabletop Scratch MP3/CD Player With USB Logo
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
rhodesworks
Are you a Numark Music Expert? Answer questions, earn points and help others
