Question about Haier RWT360BW 3.0 Cu. Ft. Capacity Top-Load Washer 6 Wash Cycles 5
Problem during wash cycle
The unit is only one year old, and the washer is making weird sounds while on the wash cycle. The sounds is like a grinding sound, also before the grinding sound happens there is a sound like it is caught on something and cant spin. But the sound is not there on the rinse cycle, yet. Any ideas what that might be?
    Top Expert:
  • Haier Master
  • 26,637 Answers
Possibly a foreign item like small change or a piece of metal from an article of clothing, pocket?
Posted on Mar 19, 2014
SOURCE: Spin cycles doesn't work, tub full of water
Did you install the bottom plate yourself? They are tricky and the instructions are a bit unclear - you want the bump side out so that bump goes towards the floor. If you install it with the bump going up toward the dryer, it gets all buggered up. Hope that helps!
Posted on Dec 06, 2008
  • 4 Answers
SOURCE: Keeps on rinsing and spinning over and over again
Aha! Mine was doing the same thing and I also noticed that there was some excess water in bottom of the tub - not the tub that the clothes go in but the one that that tub is sitting in. Does that make sense? Anyway, I cut the zip tie that holds the drainage hose, brought the hose as close to the house as possible and siphoned the excess water out of the tub. After this I tried a small test load and it worked no problem. I think the fact that there was this excess water left in the machine made the load too heavy to start the spin cycle.
Hope this helps.
Posted on Jan 22, 2009
  • 686 Answers
SOURCE: Rinse cycle not happening
CHANGE THE LID SWITCH AND OR TIMER
Posted on Apr 09, 2009
GodBlessU
  • 3513 Answers
SOURCE: Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Posted on Oct 13, 2009
Testimonial: "Thanks! I guess you're right. The belt seems to be too loose and shows signs of wearing. Already ordered new one. Thanks again!"
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
2 year old stainless steel dishwasher making weird sounds
are u hearing any metal grinding sounds or is it making a noise like something is breaking theres a pump located down the bottom of the unit and depending on how you wash your dishes for example if you wash them before you insert them into the dishwasher or if you put them in with food on them would consitute your next course of action if you do insert them with food on them then you would need to check the pump and the chopper area you might want to call a technician if the problem persists. hope this helps try running it through the full cycle if tere is something wrong you will get an error code
Jul 13, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Grinding sound during spin cycle
Is this a front loading machine? Also whats the model number when you open the door? If this is a front loading machine and you haven't been using HE soap, it's almost certain it's the brearing.
May 25, 2009 | Washing Machines
Noisy wash cycle
if it's 10 year old it's not worth repairing if the transmission is bad.  However, if it's only the $20 coupler that connects the motor to the transmission.  Fix it.
Mar 29, 2009 | Kenmore 24032\24036 Top Load Washer
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Kenmore Elite Oasis 110.2706 Top Loader Grinding Noise
If you remove the back panel, there are two pumps towards ethier side at the botom of the tub. If you remove the back hoses (have some towels ready) You may find something in one of the two pumps.
Jun 13, 2008 | Kenmore 24032\24036 Top Load Washer
Haier RWT360BW 3.0 Cu. Ft. Capacity Top-Load Washer 6 Wash Cycles 5 Logo
167 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
