Question about Garden
Engine will not run wide open
Engine starts easily and idles ok,but will not run wide open when I give it full throttle.not enought rpms to use
    Problem Solver:
  • 6 Answers
You need to make sure there is not a fuel restriction first check the fuel filter, then the lines. If these seem ok then adjust the High speed rpm, there should be two adjusters one for High speed one for low speed(when the throttle is fully engaged.Do small adjustments at a time.
Posted on Jun 14, 2009
What is the proper carberator adjustment
Start with 1 full turn out from the closed position on both the idle and high speed mixture screws. After the engine has warmed up, hold the throttle wide open and adjust the high speed mixture screw until the engine runs at the highest RPM then turn the screw counter-clockwise about 1/8 turn.
Next, turn the low speed mixture screw in whichever position gives the best idle.
After making these adjustments, check the throttle response. If the engine hesitates when applying the throttle, turn the low speed mixture screw counter-clockwise about 1/8 turn.
Jan 30, 2015 | Garden
2004 GMC YUKON DENALI idling rough and trouble starting
unless you want to blow up the intake stop giving it gas before you turn it over what you are doing is dangerous all you are doing is dumping raw unburned gas into the bottom of the intake to the motor, one of these times you go to start it it will do this boom really loud then die, it will lift the whole back end of the vehicle off the ground, then if you try to start it again okay I edited the answer also could be your catalytic convertor plugged is the exhaust coming out good, change the sensors whatever you do stop pumping the gas if it wont start now get in as you need silence so shut the door and the radio off can you hear the fuel pump? it will sound like a huum for a few seconds if you cant there is your problem all I can say is stop pumping the gas as that's why its running bad you are burning out the sensors and all the computer code stuff and wasting expensive gas too. you prolly fouled your plugs as well.
Mar 07, 2017 | GMC Yukon Denali Cars & Trucks
SUBARU EX21 GAS ENGINE RUNS WIDE OPEN WILL NOT IDLE
adjust jet to full close then open quarter turn , check manifold for leaks .sounds like the gasket leaking not tight ,
Apr 08, 2014 | Garden
The bike idles and runs great at idle but if I rev the engine and let go of the throttle there is a little rattle. Also if i crank the throttle it will rev to around 7500 and at wide open throttle the rpms...
the rattle may just be vibration or a failin bearing-old bike--carb shud be takin apart-cleaned-and ajusted if problems get worse--buy a repair manual thats what the pros use
Apr 10, 2010 | 1984 Honda VT 500 C Shadow
Cranking & Idle issue 92 Isuzu Rodeo
could be many things. Could be choke causing problems, could be engine temperature sendor bad, could be EGR. When you mean engine light comes on do you mean service engine light coming on? Probably has codes set which means something is gone wrong and setting a code that tells the tech what is wrong or what to look for. Have you changed your fuel filter lately?
Jul 28, 2009 | 1992 Isuzu Rodeo
I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke engine starts and runs fine in neutral try to accelerate under load and it only will pull about 2800-3000 RPMs and wont go any faster it will rev fine in...
Reving in neutral does not mean the same thing as under load. If you need to pull 4500rpm under load and for an instant the load was gone, you would probably overrev to 6500. With the cover off and motor not running move the throttle to full forward. Look at your carbs and see if the throttle plates are wide open. If they are not all wide open take it back to the dealer. The throttle adjustment is off. You need the full range of travel from idle to topend.
Jun 25, 2009 | Light Outboard Motor Boat Bass Fishing...
I get it started it runs as long as you have it wide open but you let of the gas it dies
This might require adjustment of the hi speed carb screw, the lo speed, and the idling screw as well.
The engine needs to be good and warm, you need to be certain you have a fresh fuel mixture in the tank, and you should check the air filter because it too affects the way the saw will run at low speed and idle.
I would start with the hi speed adjustment screw since wi does start. Fire it up and run it a bit to make sure you have it warmed up.
You may need someone else to help you hold the saw while you make these adjustments. With the throttle wide open, turn the hi speed screw slowly, in increments of 1/4 turn, to the left. It may be just a bit off. The objective here is to turn one way until it sputters or runs a little rough. Then turn it the other way until the engine smooths out. Continue to turn in the same direction until it again runs rough. Then turn back about halfway between those two points.
It should run well at wide open throttle. Place your screwdriver in the low speed adjustment screw and turn to the left, in small 1/4 increments like you did before. The objective here is to adjust to the point where the saw will throttle up quickly and smoothly, and more and more from an idling position, or as close as you can get.
If you find you don't get that, and the ramp up is choppy and unsmooth, adjust in the other direction. Eventually you should get to a point where you have quick response to your throttle. You should get to a point where it runs without being wide open.
If it fires up easily and throttles up smoothly but won't idle, the you need to adjust the idling screw. Adjust it until the chain begins to move on the bar when you let the throttle go. Once you get to the point where it idles with the chain moving, back off the adjustment until the chain just stops moving.
Make sure the air cleaner is clean. You may have to clean the carb with spray carb cleaner while it is running at full throttle. If you do, spray a tiny bit at a time, as it will almost kill the engine.
Finally, after all this work, invest in a new spark plug, even if the one in it isn't that old.
Sirwriter
Jun 15, 2009 | Garden
Starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
May 19, 2009 | Husqvarna Chain Saw 20" Bar
I need a manual for a homelite gas hedge trimmer HT-19 I need the factory settings for the carb. bottom out screw turn out 1 1/4 turn? Have to hold throttle wide open to run.
Hello cosorio70:
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Homelite Garden
Carb adgustment? initsial setings. for a kowasaki fc290v on a lil john deere rider?
Hello raptorboyz:
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Garden
Garden Logo
378 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
