Question about Watts Onan Portable Generator - 4000 , Model# 5500
Onan 7000 generator runs but does not produce electric to rv
Generator Runs good but does not provide power to inside of r v
    Sergeant:
  • 415 Answers
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Posted on Jun 24, 2014
4 Suggested Answers
joboo1
  • 257 Answers
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Posted on Mar 02, 2009
  • 332 Answers
SOURCE: I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Posted on Mar 07, 2010
SOURCE: RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Posted on Mar 15, 2011
I have an onan marquis 5500 watt RV generator that runs fine ,but won't generate.
Call Onan and tell them the Inverter Board is bad. If you're not producing AC Power, have them send you a new board or warranty the entire genset. It's unusual for Onan products to go out like that, but not unlikely that this is the source of the problem.
Typically, the DC motor outputs at 12 volts, so the leads going in to the inverter are only going to be a ground and a positive lead. Should be very simple to replace. Worst case scenario is you can hook an external inverter up to the DC leads on the front of that generator. Might not get the full 5.5kw from the system, but you'll be able to produce some power.
Oct 16, 2013 | RTO Cummins Onan HomeSite Power 5500
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Jan 17, 2013 | Onan Marquis RV Generator 7000 Watts Gas
My Onan Marques Generator runs but not swap over to 120 volts
What do you mean won't swap over to 120Volts? are you referring to a transfer switch not switching over to generator?
Dec 17, 2012 | Onan Marquis RV Generator 7000 Watts Gas
No power coming out of generator or breakers in our rv
Is there power at the generator output leads, where they terminate? Find out first that will isolate a generator, or transfer switch error
Oct 23, 2012 | Onan Marquis RV Generator 7000 Watts Gas
I HAVE A 5.0BGE ONAN GEN SET IN MY RV IT RUNS BUT THERE IS NO ELECTRICAL POWER TO RV ALL FUSES AND BREAKERS OK. ANY HELP APPRECIATED
Possible solution: if it's been sitting idle for some time, you might need to flash the windings. see this link:
http://www.endtimesreport.com/dead_gen.html
If you're uncomfortable doing it yourself, your Onan dealer can do it in 10 minutes.
Don't forget to check the circuit breaker on the generator itself!
Sep 01, 2011 | Watts Onan Portable Generator - 4000 ,...
Mar 07, 2010 | Watts Onan Portable Generator - 5000 ,...
Our onan generater runs but the power in the rv comes & off,
if ur problem is why does it get loud when the power is off...the answer is GLATOR calibaration..
if u have any further questions email me at sal_kh_sab@yahoo.com
Aug 19, 2009 | Coleman Powermate Powermate 5000W...
Rv Generator does not turn on inside power, but cranks great
The regulator could be inside the gen. Maybe under one of the covers on the front. I'd poke around and take a cover or two off and look it over. You may be surprised!
Jun 22, 2009 | Electronics - Others
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
457 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
