Question about Philips Magnavox 20MT133S 20" TV
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT conversion advice channel, which comes in very snowy. What can I do to solve the problem
    President:
  • 1,996 Answers
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Posted on Jun 17, 2009
DEAR TEAM! I AM 82 OLD MEN AND MY BEST FRIEND IS MY OLD TV. NOW MY DIGITAL STREAM BOX 9900 DOES NOT WORK, BECAUSE LED IS GREEN . HOW I CAN FIX THIS PROBLEM. NAUM. MY E-MAIL is NAUMZIS@VERIZON.NET
It sounds that your digital stream box have to be re-tuned. If the tuning is out, this kind of fault can occur. just do a hard reset to this box, before doing a re-tune. To make it a hard reset, just unplug the device from AC mains wall socket, and then replug it back after 15 minutes or so. The device will reset itself. If you do not know how to re-tune it, just download its user manual, and refer it. Download it from this link. https://cbsdallas.files.wordpress.com/2011/01/radio-shack-digitalstream-dtx9950.pdf
http://electrohelponline.blogspot.com/
Aug 21, 2016 | Televison & Video
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Maxent MX-42HPT51 plasma tv and using an
Yes if your favourite channels are in hd
Nov 04, 2017 | Televison & Video
Need codes for remote model number uk1a if it will work for converter box digical stream model number dtx9950
Your remote is only able to control TVs and DVD players. It will not control your DTV Converter Box.
Here is the remote (Apex UK1A) manual:
http://remotes.com/remotes/documents/Apex/UK1A.pdf
Here is your DTV Converter Box (Digital Stream DTX9950) manual:
http://cbsdallas.files.wordpress.com/2011/01/radio-shack-digitalstream-dtx9950.pdf
Jan 06, 2014 | Apex Digital GT2715 27" TV
Have a Magnavox TV , Rabbit ears
You may have to try a different universal remote control.
Jan 20, 2018 | RCA 3-Device Universal Remote
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
Recording with Converter
stil don't see sense in this. you lose a lot of quality.
Record direct to your recorder or is this TV with build-in receiver or so? You need al compatible digital devices with according stream codecs or be lucky to have RCA jacks out..........
Apr 20, 2009 | Philips Magnavox 20MT133S 20" TV
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
Philips Magnavox 20MT133S 20" TV Logo
779 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
