Question about Sharp LC-15AV4U 15 in. LCD Television
My Sharp LC-15AV4U wont turn on . I check the capacitors in power supply and they dont appear puffy they look ok. What is the possible cause.
My LC-15AV4U wont turn on . The Capacitors in the power supply appear to be good. What is the possible cause.
    Top Expert:
  • Sharp Master
  • 35,531 Answers
Capacitors can be defective without visual indications such as bulging.
Posted on Mar 19, 2014
4 Suggested Answers
  • 308 Answers
SOURCE: If my Sharp Aquos 37in LC-40C37U tv needs to be
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Posted on Apr 30, 2010
Testimonial: "Thank you. I will get another board."
  • 15 Answers
SOURCE: Sharp LC-15AV4U 15 in. LCD Television
Sounds like a lamp error.... either a defective or broken lamp within the LCD1.gif panel itself, or you have a bad inverter.
Posted on Apr 02, 2008
SOURCE: Sharp model # LC-32DV22U. dvd stuck and it wont
January -6- 2010.no response from anyone.donated it!
Posted on Jan 07, 2010
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
My Sharp 13" turns off in 5-7 secods.
Likely power supply--bad caps etc----5 years and 13? inch---cheaper to replace most likely---if you manage to get it apart look in power supply for puffed up on top caps----age of set makes this possible and not real expensive or difficult to repair.
Oct 23, 2012 | Sharp LC-15AV4U 15 in. LCD Television
Sharp Aquos LC-C4654U The TV blacks out frequently. The blackouts last aprox. 1-2 sec and when the picture reappears, the blue box appears in the top right corner (just like when the tv is initially...
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sep 13, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I have a tv sharp lc 32sb24u dont turn on the green led is blinking i have voltage in both sides of the power switch 3.2 volts
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem, take care in handling the fault.....
May 25, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My power shuts off after 2-3 seconds
Hi:
This usually an indication of a power supply problem, have the PS checked for bad capacitors in the output section of the PS.
Jan 24, 2011 | Sharp LC-15AV4U 15 in. LCD Television
My sharp 15" LC-AV4U TV turns off within 5 seconds of when it is turned on any help
Jan 26, 2010 | Sharp LC-15AV4U 15 in. LCD Television
Sharp Aquos LC-20B6U-S TV NOW HAS NO SOUND OR PICTURE. IT APPEARS TO COME ON BUT WITH NO PICTURE OR SOUND.
This can be caused by many different things. Check power supply fuses. If ok suspect inverter board which drives screen. Check for bulging capacitors and open transformers or just find replacement cost using numbers on board. That may fixya.
May 29, 2008 | Sharp Televison & Video
Sharp 20mu14
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Sharp LC-15AV4U 15 in. LCD Television
Jun 04, 2007 | Sharp LC-15AV4U 15 in. LCD Television
Sharp LC-15AV4U 15 in. LCD Television Logo
85 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
