When my room gets very warm the sound on my tv goes off and to get it back on i have to turn it off
Nordmende 32 hd ready tv
SOURCE: power lock enable
To get rid of the power button enable you need to either press and hold the power button on the tv ( not on the remote control pad) for approx 15 seconds or if that does not work do the same using the source button
Posted on Jul 18, 2008
  • 174 Answers
SOURCE: no digital sound coming out of our tv
im sorry to hear that(please excuse the pun does it have sound when whatching for example normal tv 1/5 or a dvd
Posted on Aug 05, 2009
pjbaldi
  • 8 Answers
SOURCE: dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Posted on Jun 02, 2010
  • 8457 Answers
SOURCE: 32" Element HD LCD TV screen often sticks to one
The tv have a long board called a LCD inverter board it is dying.This LCD inverter board help the tv LCD screen panel to have a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish a new long LCD inverter board for the replacement.
Posted on Oct 09, 2011
SOURCE: i have a luxor 32" lcd tv and i cant get my surrond sound speakers to work. how do i do this?
Hi well surround sound speakers require an "Interconnection" box, that is a box with Jacks that the Red & White stereo audio plug into, on one side, and the 3 SS speakers plug into the "Other side" as it were. Usually with SS we have a Rear, Front and Sub Woofer, as this means 3 sets of speakers must mate with the 2 outputs from the TV etc. So the "Line Out" stereo output from the TV, which are usually the Red & White, is the output to the interconnection box, from there it feeds into the SS decoder, some plug directly into the decoder itself, and don't use an interconnect box, but it's all the same in the end. The stereo output is fed into the SS decoder, and then SS signal is extracted from the sign in, and routed out to the appropriate speakers.
Posted on Oct 24, 2011
When a overhead light is switched on,the tv sound goes and picture breaks up
sounds like distortion from this overhead light you are turning on.
try TV else where in another room for example.. see if it reacts to other equipment being turned on
Jun 02, 2013 | Panasonic TX-L32C4B 32-inch Widescreen HD...
Tv wont turn on
does the light stay or blinking and how about the screen display totally black or a white screen. you can see in a dark room if their is a white screen. if totally black screen then with sound the cause is could be bad inverter board or screen back light. if a white screen it was the t-con board not working good.
Oct 04, 2012 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
When i turn it on the light under the screen is blue then goes orange and i have no picture/sound, kind of like when you select video and the dvd is not turned on
Tries unplug,replug the tv and cable box an hour later.The tv should now,reset itself back to the factory setting.The cable box resetting and it upgrading it softwares.The tv should work now.
Oct 21, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Slow picture
POWER SUPPLY PROBLEM STOP USING YOUR TV OR BIGGER PROBLEMES WILL GOME IT WILL COST ABOUT 200 DOLLARS TO REPAIRE
May 30, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Tv turns on but no picture shows. But there is
you may have a bad Y sustain board.
google it for proper part replacement
for Samsung LE32R41BD
Fosg2000, Please rate me
Mar 15, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
TV turns on screen is fine. Screen goes black
The problem can be bad caps in the power supply, or the backlight inverter board is bad, depends on how much you know about repairing electronics, you may want to look inside first for bad caps. You can look for replacement boards here: www.shopjimmy.com
But report back what you see inside first so we can you further. My had scrambled picture after warm up, yours will more likely to have this problem later on also. http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Jan 31, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Menu on a Philips-32PF7320A-37B
try leaving the TV unplugged overnight (at least 8 hours). this should reset televison to origional defaut settings. If you are using a remote, you should use new batteries or put it in another room and use menu buttons on the tv itself it is equiped.
Mar 31, 2009 | Philips 32PF5320 32 in. HD-Ready LCD...
LTV-32w1... at wits end.
Its problem with Inverter board. Please check its connectors, unplug and reinstall them.
Aug 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Bad picture
Sounds like a dry solder joint. When the tv is on for 4/5 mins the crack warms up and the gap spreads. When you turn off it cools and when it warms up it starts again.
Mar 18, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
