Question about Xante Ilumina Digital Color Press Printer
Having issues with ram check and initializing..xante ilumina keeps saying intializing and then ram check....keeps doing this back and forth...sometimes we can unplug the printer and restart and it wil
Can this be fixed?
SOURCE: Xante Ilumina
You need to install duplex in your windows driver printer dialogue
Posted on Oct 12, 2008
rooboy
  • 24 Answers
SOURCE: full bleed printing
update on this, you cannt full bleed on the lead or tail edge, due to the sensors telling the unit when the paper starts to feed, and when the sheet ends as it enters the machine, you can only bleed to edge on the sides, by overstating the page size width.
Posted on Dec 08, 2008
SOURCE: Xante Accel-a-writer 3N Printer Not responding
I just signed up today. Are you still having the responding
issue?
Posted on Sep 11, 2009
  • 202 Answers
SOURCE: how to install xante ilumina drum units?
When you unpack the drum it has like a white nylon and three orange plastics. Remove the three plastics(tapes are holding the plastics) and at the end remove the white plastic it has an arrow. Do not touch the drum. Make sure not to much light hits the drum. You have four drums remember to sit correctly the drum and to its correct position.
Posted on Mar 16, 2010
long05891
  • 13 Answers
SOURCE: please what can I do
the 133 fatal error
C head
after turning ON the power or when cover is closed, the sensor detects that the unit is missing.
1. is an Error message displayed? yes
ICheck the OED head unit.
2 is the LED head properly mounted? no
Turn ON power again
3 Does the Error take place again? yes
Replace the LED head Assy.
Posted on Mar 04, 2013
Magenta Stained product on a Xante Ilumina
i want to ask few question, are you using correct envelopes for this machine or can you use any type, is the weight of paper like is 20lbs
paper, or is it cheap 99 cents paper.
the port where the color ink is spout or ejector port is issue.
call the manufacture customer care center ask for technical services.
go online to the following sites for more help or informations.
www.ask.com/mfg.name/make/model/
/service/manuals/
/operational/manual/
/troubleshooting/guide/
/FAQ/
/customer/service/telephone#/
Oct 06, 2015 | Xante Ilumina 502 GS Digital Color Press...
How do i fix the little black piece that broke off of the fuser exit sensor on my Xante Ilumina?
Amanda,
The problem is related to the paper exit assy. Their is no problem with your fuser assy. Take a look at the exit document related to your problem. Usually that is cause when removing a paper jam, that switch flags break for pulling the paper in the back direction. You would have to replace the paper out exit swicth black actuator.
Oct 03, 2014 | Xante Ilumina® 502 Laser Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
230:fatal error with Xante Ilumina
RFID Reader Not Installed
Check Connections. Replace the RFID Relay Board Replace the Engine Board.
Jan 09, 2013 | Xante Ilumina Digital Color Press Printer
How to get brilliant prints on xante ilumina, the prints come out matte all the time
it may be what you are printing your pictures on try different printing materials
Sep 19, 2012 | Xante Ilumina Digital Color Press Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
How to install xante ilumina drum units?
Jul 02, 2009 | Xante Ilumina Digital Color Press Printer
What is wrong with this Illumina???
I have been running this machine for 2 years. The only way I can run is too 1 printer media to plan - on Ilumina display panel 2 media weight to auto on Ilumina display panel - 3 When printing in printer dialog be sure set these options -  -printer features-insert option - set media type to Printer Setting
I have tried changing the media types as well and will not work for me- but setting to auto works. http://www.inkcoverage.com
Oct 14, 2008 | Xante Ilumina Digital Color Press Printer
Xanté Ilumina: 020 fatal error
unplug power. open rear panel (2 thumb screws) check fitting of the ROM chips, restart..
020 relates to Slot A ROM DIMM
May need new ROM, or that CU PCB if unsuccesful
Jul 21, 2008 | Xante Ilumina Digital Color Press Printer
Error codes
let me know your error codes, i may be able to asist....
disconnect the power cord, open back panel(hinged door and connecting panel(2 screws). check the security of all the connectors on the 2 main circuit boards.
also on the RH board, pull out and reinsert the memory chipsets, to make sure they have good contact..
then repower up...see what happens..
Jun 05, 2008 | Xante Ilumina Digital Color Press Printer
21 people viewed this question
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
