Question about Lexmark C925DE Laser Printer
Power turns off
Power automatically shuts off after 10 seconds
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
Tip
Viewsonic monitor Lock and Unlock instructions
OSD and Power Lock Settings
OSD Lock: Press and hold [1] and the up arrow UP for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
OSD Unlock: Press and hold [1] and the up arrow UP again for 10 seconds.
Power Button Lock: Press and hold [1] and the down arrow DOWN for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display?s power will automatically
turn ON when power is restored.
Power Button Unlock: Press and hold [1] and the down arrow DOWN again for 10 seconds.
May not work on ALL Viewsonics
http://www.viewsonic.com/assets/027/7939.pdf
Service manuals: http://ftpkuban.com/FTP/Manual/ViewSonic/
on Apr 14, 2010 | Computers & Internet
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
The off and on button is on but the screen says it is shutting down, but it will not shut down or let me go on to another stage. I have pluggged and unplugged it. It still comes back to shutting down mode
Hi
Try resetting the printer, follow below steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
Regards,
Rizwan
Jan 27, 2010 | HP Officejet J5780 All-In-One InkJet...
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
TO RESET MY PRENTER MFC-240C
Hi, to reset the MFC-240C, you can just hold the power button down for several seconds, and once the printer shuts down, press the power button again to turn it back on.
If that doesn't work (which sometimes it won't if you have a paper jam) just unplug the printer's power cord for 10 seconds, then plug it back in. If the printer doesn't automatically turn back on, press the power button.
Dec 07, 2009 | Brother MFC 420CN All-In-One InkJet...
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Mac Mini G4 turns itself ON
Have you looked into System Preferences>energy saver>schedule? Maybe it's set up to start itself. I have my mother's mac set to start up and shut down automatically. Just a thought.
Jan 09, 2009 | Apple Mac mini G4 Desktop
Lamp automatically turns off
You have to follow the manual reset instructions in the user manual. Something like press and hold both brightness buttons for 10 seconds. See the manual.
Jan 01, 2008 | InFocus ScreenPlay 7205 Multimedia...
Lexmark C925DE Laser Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
