Question about LG DLE5977 Electric Dryer
My dryer will be 3 years old next month and the seam of the drum has come apart and my cloths are getting caught. lg will not stand my their products. the dryer only has a one year warranty no mater what.i will never buy lg products.The repair people say they can not fix it. I have to replace the drum. Is it worth it????
    President:
  • 1,865 Answers
If you have to replace the drum in 3 years, then i would imaging another drum will wear out within 3 years. Sounds like garbage to me, I advise replace the dryer. Sell the LG on ebay for parts
Posted on Jun 14, 2009
The drop has broke
Check your owners manual, or call samsung. These dryer drums, if stainless are usually warrantied for multiple years or lifetime as listed in your manual. Consumer to pay all other charges like other parts, trip charge, and labor if over 1 year old. The stainless drums frequently split on the seams. Pleazer Appliance...
Apr 06, 2014 | Samsung DV218AE Electric Dryers
Clothes getting caught in drum of Kenmore dryer
The repairman is trying to upsell you to a replacement drum. The felt sealer can be an expensive item to replace. Go to www.repairclinic.com and enter the model of your dryer. With luck, you will be presented with a list of common replacement parts that will give you some idea of cost.
Apr 28, 2017 | Dryers
Clothes getting caught in Kenmore dryer
The bearings under the drum may have failed, making the drum drop, so the gap is bigger. Replacing drum or bearings is a lot of work, cheaper to replace the dryer. Or you could make a plastic ring yourself that is thicker to fill the gap....
Dec 27, 2013 | Dryers
My dryer is ten years old. A few months ago, some of the clothes would come out with rust stains on them. Some of the clothes would get caught in the seams which would cause staining, tearing and...
I would suggest replacing the front drum bearing. Sounds like the gap is now excessive, obviously allowing clothes to get caught up in there. Drum must be removed from the dryer to do this.
Good luck, hope this helps.
Aug 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer is leaving brown marks on clothes. it is either a burn mark or they are getting caught between dryer drum and shell, not the door
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Steve
Mar 29, 2010 | Amana ALG331RAW Gas Dryer
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Dryer is grabbing and burning clothes.
Take a putty knife or spatula and insert it in the seam on the dryer between the top panel and the rest of the machine, and pry up the top. The top will pop right off and you will probably just need to tighten some screws or replace a small part at the most.
Oct 17, 2009 | Frigidaire Dryers
Crack in drum at seam
We had the exact same problem with our LG dryer but the crack was in the front near the door. The service tech as well as the engineer from the LG R&D department both agree that it is a manufacturing defect...the result of a poor welding job by LG. The service tech replaced the dryer tub today and the dryer is as quiet as when we first bought it. I paid for the part and the repair myself to get it fixed quickly. The service tech said to use it with the crack could be a fire hazard since the heating element is open under the tub. However, the service company we use will reimburse me for the cost of the part if LG agrees to reimburse them. I am in the process of working with the resolution department to get them to agree to pay for this part. It is no longer under warranty but since there engineer has agreed that it is a manufacturer defect, I am hopeful I will get my money back!
Oct 05, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
There is a knocking noise when drying clothes
Look for a crack at the welded seam of the dryer drum. Noise maybe coming from the crack when it passes over the drum support rollers. Check front and back side of the seam. Solution is to replace the drum. If this is not found, please describe your symptoms in more detail.
Dec 23, 2008 | LG DLE0442 Electric Dryer
LG DLE5977 Electric Dryer Logo
169 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
