Question about Palm (3206WW) Wireless Headset
Initial charge I just received my Palm Bluetooth wireless headset, for my Treo 650. I plugged in the Palm charging cord to a clean, UPS fed, 120 volt, properly grounded, standard American power outlet. The blue light on the multifunction button blinks for a split second, then goes out. This happens every time you plug it in. Holding the button down does nothing. The light only comes on when first plugged in, but at no other time. The same power cord charges my Treo without a problem. The unit appears dead other than the one blink of initial blue light. Can you help me please?
  • 7 more comments
  • Jose Jan 16, 2008
    I have the same problem, it seems there are a few entries like this one but no solutions yet. Any one can help?????
  • josh3ber Mar 05, 2008
    I just got mine, tried to charge it and the same thing happened, only a split second blink. I went online trying to find out what to do and came across this website. I hope I or someone can find an answer.
  • Anonymous Mar 11, 2008
    I have the same problem, when I plug the bluetooth in nothing happens.
  • jonatfixya Mar 11, 2008
    I have the same problem. When I plug it in nothing happens. The blue light flickers for a moment but that is it. Please advise what you recommend. It looks like this is a frequent problem - What is being done to resolve it?
  • Anonymous Apr 14, 2008
    Same problem.
  • Anonymous May 08, 2008
    another same problem!!!
  • Anonymous May 30, 2008
    Same problem, second time (this is my second unit with this problem straight from the package). Third defect in a row!
  • kcchick4122 Nov 29, 2008
    I can't return mine. It was a present for last christmas.
  • blaineso Apr 30, 2009
    2nd one in a row 4 me too.  just a flicker, then nix.  I swear they sent the same one back to me. damn
Does anyone have an answer to this. Or just return it.
Posted on Jan 09, 2008
My emerson bluetooth model EM228WM cannot pair to my cellphone LG i charge them for 8hours and took out my cellphone battery like the customer service said yesterday but still doesnt work pls give an...
You may call customer service at 877-768-8483 for a live rep to assist on the phone with charging as LG is one of the most common phone which pairs with no issues.
Oct 29, 2010 | Southern Telecom Emerson Bluetooth Headset...
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
My grandson's Palm Treo 650 will ot charge on wall, car or computer cords. No "drop" or "water damage" issues. He does not have his software. What sould I do now? Is there a reset button? Need he
Reset would not help with this kind of issues.
If it does not charge , and battery and charger are good, that means that there is a broken contact in the DC socket on the PDA, where you plug the charger.
The fix requires disassembly and a delicate soldering job on motherboard, and must be done at a repair shop.
May 28, 2009 | Palm Treo 650 Smartphone
Lost speaker on my Treo 650
This problem usually occurs when the headset jack is busted. If there is sound through the headset but none when you plug it out, then a busted or faulty headset jack is definitely the culprit.
Apr 24, 2008 | Palm Treo 650 Handheld
Palm Treo 650 doesn't see bluetooth headsets, AND wired headphone jack is shorted
Had a similar problems. Throw out wired headsets with shorting problems. Their too cheap to try and fix.
Try rebooting the phone, then make sure the wireless headset is on. The trick is to get it into "trusted devices", so when you get the phone to seek new or nearby devices, you need to push the button on the earpiece so it sends a signal at the time the phone is trying to find it. It took me a number of trys, but finally got it to work. I use Verizon and they were quite helpful, even though the phone was "out of warrenty". I was re-activating my phone after not using it for a couple of years.
Mar 08, 2008 | Palm Treo 650 Handheld
Palm treo 650 wont power up
It may be past the point of turning on.
If this is the case, if you connect it through the USB cable to your computer for a little while, it can get a small charge.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
If you can then power it on afterwards, connect it to the regular power charger.
Jan 06, 2008 | Palm Treo 650 Handheld
Bluetooth Problem
I had that problem once. I had to hard reset it and that fixed it.
Dec 01, 2007 | Palm Treo 650 Handheld
Palm Treo 650 charging port loose and will not charge
I had this on mine, it seems to be a wear and tear issue, mine has gone back to Palm for a paid repair as it is out of warranty:-(
Nov 09, 2007 | Palm Treo 650 Handheld
Palm (3206WW) Wireless Headset Logo
157 people viewed this question
Top Palm Radio Communications Experts
Are you a Palm Radio Communication Expert? Answer questions, earn points and help others
