Question about Rowenta DM-253 Powerglide 2 Self Clean Steam Iron DM253
Self cleaning instructions
I need self cleaning instructions for this model
4 Suggested Answers
DiYerTech
  • 70 Answers
SOURCE: Rowenta DM273 Self Cleaning Function
Attached below is the Rowenta website to obtain PDF copies of the manuals. If the hyperlink does not work, cut and paste it into your browser's address line. There are also links to download Adobe Acrobat Reader to allow you to view and print the documents if you do not have this program. Please advise if you find this helpful...
http://www.rowenta.com/rowenta/frame.aspx?page=http://www.rowenta.com/rowenta/consumer_care/use_n_care/downloadInstructions.aspx?RblCategory=Download
Posted on Jul 14, 2008
hmerchant110
  • 7191 Answers
SOURCE: lost my self cleaning instructions, please help
You can download the complete instruction manual in PDF format by clicking this link.
The detailed steps for self-cleaning procedure is given on page 6 of this manual.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Posted on Jul 16, 2010
SOURCE: i have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
Posted on May 04, 2011
I've lost my instructions for how to clean my self cleaning iron, need step by step instructions.
Heat to highest Heat level , then press self clean button on the iron
Mar 17, 2015 | Irons
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Lost my self cleaning instructions, please help
Jul 15, 2010 | Rowenta Effective DX1900 Iron with Auto...
I need to descale my iron Do I just fill and dial self clean?
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 16, 2009 | Irons
How to use the self clean feature on a tefal steam iron
I cleaned mine with alcohol and clean terry cloth. Took some work but it eventually got clean.
Dec 24, 2008 | Irons
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Tefal self cleaning iron Ultraglide
Go to Sunbeam.com. They don't have this model - but there is an instruction manual for a 39?? - I read it and from what I remember it is the same as the 3957. It is a pdf file - page 8. - Those are the instructions.
Jan 06, 2008 | Irons
Rowenta DM-253 Powerglide 2 Self Clean Steam Iron DM253 Logo
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
