Question about One Step Ahead New Holland Tractor Set
New Holland Tractor TL100A. Put in new battery in Feb. Won't go forward or backward..no insturment panel
Have had to jump start it several times even after that. I jumped it yesterday, it startedm, but the tractor will not go forward or backwards, the instrument panel and radio will not come on. Mechanic checked the fuses and relays and wires. All fine. What could the problem be? computer fuse to computer???
  • Leslie Aiton
    Leslie Aiton Mar 22, 2014
    There is a secondary fuse box under the hood. The fuse is under there that
  • Leslie Aiton
    makes the tractor go and lights up the instrument panel. It is up and running
TL80 New Holland tractor will not start
Check connections at battery, starter solenoid and starter motor, make sure they are clean and tight. Check the both ends of ALL wires. Check starter is not jammed. Check starter mounting bolts are tight. Make sure battery is good by using jump leads from known good battery (like your car).
Nov 17, 2013 | Garden
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
Dec 21, 2012 | Cars & Trucks
I accidentally hooked my battery up to my bike backwards and put a jump starter up to it backwards as well. When I started to smell the battery I realized my mistake. I hooked it up correctly and it...
May have a blown main fuse or several fuses. The larger main fuse can be located around the battery and even sometimes in the fuse panel. Hooking up the jumpers backward may have also cause electronic damage to things like the ecm, ignition modul etc. If the damage is electronic is may be major so carry it to a shop and let the shop look at it.
Nov 15, 2012 | Motorcycles
New holland TC33DA won't start
Sounds like a bad starter. Try giving it a few good taps while turning the key. Sometimes they can get warped and get stuck. Had to start my car for weeks doing this till I could afford a new one. Could also be the solenoid too but im not sure if it would even click if that was bad. Good luck.
Oct 19, 2012 | One Step Ahead New Holland Tractor Set
New holland tractor won't start just clicks
check both batt. termial ends,also check cenections at the starter and the ground wire,if that wont fix it next maybe charge batt .
Jan 07, 2012 | Garden
I have a 42" Craftsman
HI IF YOUR BELT IS LOOSE THEN YES YOU NEED A NEW BELT
IT IS A V-BELT GROUND DRIVE-95 25
PART /160855
Sep 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
Lost glow plug function
Had same thing happen on my New Holland 1630. Took the buss bar off the glow plugs and pulled them out and tested with test leads on the battery. They glowed. Put a volt/ohm meter on the buss bar and turned the key to glow position, no 12 volts present. Checked for blown fuse, nothing blown. Looked at relays. There was a glow plug lamp timer next to the start relay. Wiggled wires going to timer while asking for glow with key. Saw the glow lamp flicker. Took timer out and opened it up. Found a broken solder joint on circuit board resulting in a loose capacitor. Soldered the crack and put back on tractor. That was it! Glow plugs work now.
Dec 04, 2010 | One Step Ahead New Holland Tractor Set
One Step Ahead New Holland Tractor Set Logo
80 people viewed this question
Top One Step Ahead Toys Experts
Andrew Taylor
Andrew Taylor
Are you an One Step Ahead Toy Expert? Answer questions, earn points and help others
