Question about One Step Ahead New Holland Tractor Set
Tractor has new battery. Had to jump start it and now it wont go forward or backwards and no instrument panel lights?
Fuses appear ok, relays ok
Hooked jumper cables backwards, now windows wont roll down, air cond fan wont turn on, no power steering, All the fuses say they are still fine. Where do I even start?
This is unfortunately not good, You will have to take it to a auto electrician. Hyundai is very very touchy when it comes to electrical problems. one wrong move and you can end up in a heap of trouble. this could end up being computer issues. they will have to OBD scan to find problems. This can also set you back a penny. sorry, no good news for you.
Aug 18, 2014 | 2006 Hyundai Elantra
Reversed polarity on jump start. now wont go into gear or hold charge
OLder cars YEs you can jump it without a battery. But in newer cars that use computers and advanced Eltronic ignition/timing/ful injection you have to have power to the cars computer. without a good battery the car will not run.---------------------------------------------------------------------------------
Renault CAN Clip
Feb 01, 2013 | 2001 Kia Rio
All rear lights went out after had vehicle was jumped off
a few fuses could have blown from being jump started backwards and also if the where on with connected to another battery source
Sep 15, 2012 | 2005 Ford Expedition
New battery toyota corolla 2009
was it jumped backwards or the battery installed backwards at first look for blown fuses including the large amp fuses
Apr 14, 2012 | 2009 Toyota Corolla
After jump starting my 2004 gmc sierra the heat/ac panel and controls wont work
Blown fuse/ relay. check the fuses in the fuse panels. Remember when jump starting any vehicle from 1992 forward, to not hook the negative cable to the battery itself. hook it to a bolt or something on the frame inside the engine compartment. You probably have a bolt or rod sticking up close to te battery that says "ground here." or "place negative cable here" when jumping. Most people never pay attention to it because we were taught all of our lives to connect the negative cable to the battery so we dont look for it.
Feb 07, 2011 | 2004 GMC Sierra
I have 1981 GMC sierra pick-up. I put in a new battery. But I have no power at all. No starter, horn, lights everything. I checked fuses under drivers dash.
Check the main Fuse panel in the interior and check the main Power Distribution box in the engine compartment. If all fuses and relays are good start checking for a grounded positive wire off the battery and have the alternator tested. Check the firewall for a ceramic relay that has two wires going to it. If you have one there try running a bypass across those two points and see if that gets you power. Don't crank the motor with it bypassed but you should detect power at the lights and instrument panel if you jump across the wires.
Dec 24, 2010 | 1994 GMC Safari
I have a john deere 6400 that wont start from cold even with a new battery it needs jump leads from another tractor and then still struggles the hazard warning light and the information light on the dash...
i had the same problem, it is most likely that your fuel lines are leaking and fuel pump in tank is weak
when the tractor sits for a while the fuel drains back into the tank, thus your injection pump has no fuel in it.i solved it by replacing all the lines and i added electric fuel pump on outside of tank and connected the power to key,when i start the tractor i turn key on for a minuet or so than start the engine ,it solved the problem.
john b
Nov 16, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
01 dodge caravan instrument panel lights do not light. Can't find a reason - can't find a fuse Speedometer , tach, nothing lights or works
disconnect the battery to let the body computer reset.
had the same problem with mine when my son left center interior light on . it ran down the battery and the security system made the head light start flashing . when i jump started it i had no instrument panel lights . i disconnected the battery and it fixed the problem.
May 21, 2010 | 2001 Dodge Caravan
Grand Cherokee wont start, clicking coming from interior fuse box
Bare or burned wire, most likely battery cable or alternator cable near exhaust system which might be making contact with a metal part somewhere, off and on, because of bumps, vibration, etc.
Jul 29, 2009 | 1995 Jeep Grand Cherokee
One Step Ahead New Holland Tractor Set Logo
19 people viewed this question
Top One Step Ahead Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an One Step Ahead Toy Expert? Answer questions, earn points and help others
