Question about Gateway DX4831-01E Desktop i3 2.93GHz 6GB 1TB DVDRW
Snap in the dvd door
How to snap in the dvd door
  • 37 Answers
You find usually small hole below the door, if its there on yours, you have to put a needle in to release door manually.
Hope helps
Posted on Apr 09, 2014
DVD stuck in machine
If your handy then take off the lid, unscrew the dvd mech so you can get to the front of it and turn the pulley wheel with your finger, probably the belt has snapped
Sep 09, 2014 | Televison & Video
Dvd door keeps opening on toshiba rd-85dt
same problem i had, there is a small microswitch under the top left corner of the dvd door, the microswitch is broken, it breaks if you put stuff on top the unit and move it about, it catches the door and breaks the end of the switch, easy fix for average electronics enthusiast
Jan 23, 2010 | Toshiba RD-XS52 DVD Recorder
Camcorder disc door won't shut.
Back to supplier...unless its out of warranty....if it still operates and gives you good pictures..........!!!!.......newer systems are available and will cost less than thr repair bill....unless you have a friend?
Oct 02, 2009 | Sony DCR-DVD610 DVD Camcorder
The door wont open for me to put in the dvd on our player
Put your ear against the dvd draw and press the Eject button, if you hear a noise of a motor spinning up then the belt is either worn so its slipping or has snapped, if you hear no noise then the disk tray loading motor or the driver chip on the mainboard has shorted out.
hope ths helps.
regards jon
Aug 22, 2009 | Daewoo Televison & Video
The manual window handle on my 2003 Escort ZX2 snapped?
You will have to replace your "window regulator". Normal 0
Locate and remove the screws that hold yourinterior door handles in place (they may be hidden by snap in, or snap onclips). Remove the interior door handles. Your panel is held in place by snap in clips; use a small pry bar topull them from the door (try to get as close to, or directly under the clips toprevent them from tearing out of the door panel). Once the clips are pulled,pull the panel upward to remove it from the door. Once you have access to the inside of the door, you will be able to see the bolts that retain the window regulator, remove them, and replace the regulator.
Jun 01, 2009 | 2003 Ford ZX2
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Feb 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Hinge assembly makes a snapping sound when door is opened
This is a self closer assembly. Try getting a new self closer and replacing both parts. The part on the door and hinge. 0The door must be removed to do this.
Nov 13, 2007 | Frigidaire FRS26KF5C Side by Side...
Dvd player
Sounds like you have a faulty Drive/ Eject door motor, Snapped drive belt if a noice can be heard or the Motor driver chip has malfunctioned.
When you press eject listen for a noise like a small humming from the dvd drve part, if there is a hum then more than likely your belt has broken which is inexpensive but if nothing can be heard then its likely the motor or Driver Chip. The motor can be easily replaced if found on an auction site.
Jon
Oct 14, 2007 | Norcent Technologies DP1950 System
DVD will not close its door
Open it up (take the screws out) and see if one of the door tracks came out. Just snap it back in place.
Jun 26, 2007 | Zenith DVB317 DVD Player
Door will not open or close
i ended up retrieving the dvd out of mine after it quit coming on by taking the top cover off and taking the cover off the dvd it just snaps in place by clipping on each side.
Feb 17, 2007 | Emerson EWD7003 DVD Player
Gateway DX4831-01E Desktop i3 2.93GHz 6GB 1TB DVDRW Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
