Question about Hoover Vacuums
Floor cleaner has stopped suctioning. High pitched squeal, hot smell
This is a platinum MaxExtract model
It is probably just trash that can not be fixed but for the same price as a brand new one due to the amount of parts that will need replaced
Posted on Mar 21, 2014
  • 55 Answers
SOURCE: Kenmore progressive upright canister vacuum
Hello, Trish. It sounds like the belt needs to be replaced. You can purchase a belt for you vacuum at any Sears or probably even a local department store and are very easy to replace. Just go to you local Sears and ask an employee to direct you to the vacuum accessories department and you should find the replacement belt. Be sure to write down the model and what type of vacuum it is (i.e. Type U, Type Y, etc.). Hope this was helpful. Please take a few seconds to rate how helpful this suggestion was. Thanks and good luck!
Posted on Sep 12, 2008
  • 134 Answers
SOURCE: Infinity Shark Vacuum
YOU HAVE BROKEN THE BELT, ORDER ONE FROM HERE
http://www.sharkvac.com/partsearch.aspx?CatID=cxmdqvOilfw%3d
Posted on Feb 14, 2009
advacak
  • 125 Answers
SOURCE: motor sounds loud and high pitched
most likely your bearings are shot. it will need a new motor
Posted on Mar 09, 2009
  • 389 Answers
SOURCE: There is no suction to the floor sweeper. The
Sounds like you have two separate problems here.  If the brush bar does not rotate, probably the belt is broken. This is easily replaced, but you need to be precise about which model you've got so you get the right belt.
Loss of suction is due either to a blockage or, quite often, to a split in the short length of clear plastic hose that leads back from the brush bar enclosure.  Repair is possible but replacement is better.
If you need more help, post here again.
Posted on Apr 21, 2009
  • 75 Answers
SOURCE: Lost suction high pitched squeal
the motor or the fan needs to be replaced.both are a lot of money.
Posted on Jul 05, 2009
Download hove maxextract floor finishers model
Hi! Follow the link to view the owner's manual for the Hoover F8100900. http://hoover.com/file/622/
Thanks!
Jul 07, 2014 | Hoover F8100900 Carpet Cleaner with Max...
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
Squealing noise from the top
Take the HEPA filter out of the ball. Run the machine without it and see if it quits. My guess is that it will. You can get some scissors and cut the rubber seal off the filter and re-install it and you squeal is gone.
Aug 08, 2017 | Dyson DC25 All Floors Bagless Upright...
Wont pickup water
check dirty water tank make sure lid is on correctly and that the plunger is not stuck.
Jan 20, 2013 | Hoover MaxExtract Deep Cleaner
HIGH PITCHED SOUNDS WHEN VACCUUM IS ON
Remove all filters and turn on the vacuum cleaner and check the hose for suction.If it has good suction turn it off and remove the belt.Turn it back on and if the noise is still there you have a motor bearing squealing.It's probably time to replace the vacuum cleaner if you have a motor problem.www.sewvac.com .Most of these box store models are designed for replacement if a major component fails.
Jan 28, 2011 | Bissell Vacuums
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Jul 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Apr 14, 2009 | Vacuums
Loss of suction....HELP!
TRY TAKING THE BELT AND BRUSH OUT AND SWITCH IT ON. iF THE NOISE HAS GONE YOU KNOW YOU NEED TO REPLACE THEM.
Dec 18, 2008 | Euro-Pro NV31 Infinity Vacuum
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
