Question about HP DeskJet 5550 InkJet Printer
PRINTER PRINTS DOCUMENT LAST PAGE FIRST ( 3,2,1) I WANT TO PRINT FIRST PAGE FIRST ( 1,2,3)
  • HP Master
  • 511 Answers
Disable reverse order at printer setup.
Posted on Jun 14, 2009
Prints last page first
The solution for your problem is simple. When you print you have to uncheck the option where it says "Print last page first". Or use the following steps: 1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
If you need further assistance, just leave a comment.
May 23, 2010 | HP Officejet 6310 All-In-One InkJet...
Single page printing
OK, well when printing from the internet it quite often only prints the screen you are on, I presume, because you likes what you read, you wish to print it, well as you are on Page 3 the end of the document, thats what get printed. You actually, need to go to the File Menu, select, Print, and actually select, the type of print, there are options, Print ALL, Print Page, Print Selection, you need to set that, it sometimes remembers a setting and perhaps 3 was the last setting.. In any event don't just "Hit Print" you have to do as related, I am not sure if you can set up special "Print Now" parameters, but I expect you can, choose a "Default" setting.
Mar 31, 2010 | Lexmark X5650 All-in-One InkJet Printer
The last line of every document is cut off and the bottom half is missing as though the margin isn't long enough, but that's not the case.
Try to print a self test page using the below steps
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.If this prints fine, perform the partial reset of the printer using the below steps:
    1. Unplug the power cord from the HP All-in-One.
    2. Wait for 20 seconds.
    3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
    4. Release the buttons after the HP All-in-One starts up.
    5. The HP All-in-One will now be reset to factory defaults.
Sep 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
I keep getting a test page before printing my doc or picture
To resolve test page prints every time issue, perform the steps provided in the below webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065136&cc=us&lc=en&dlc=en
Now, perform the steps below to change the settings from last to first page:
===== From the HP Solution Center software =====
1. Open the HP Solution center.
2. Click Settings--Print Settings --> Printer Settings
3. Click Advanced Tab.
4. Under layout option select the page order from "front to back".
5. Click OK and try printing.
From application
a) Select tools
b) Goto Options
In that select print tab
c) Check the Reverse Print order option.
d) Click Ok.
Apr 17, 2009 | HP DeskJet F380 All-In-One Printer
HP laserjet 5L prints only 2/3 to 3/4 of the page of a 1 page doc
which bit is usually missing?
If it only prints the 1st 3/4 ish of the page then it could either be the page slipping a bit due to poor pick up rollers or much more likely it could be that you are sending a large file to the printer and the printer does not have enough memory.
Try printing in draft or scale down the res/size of the file you are printing
Mar 18, 2009 | HP LaserJet 5L: HP 5L Monochrome Laserjet...
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
When asked to print, it prints:Filrname, Directory, template, title, subject, arthur keywords, comments, creation date, change number Last saved on,Last saved by, Total Editing time, last printed on, I...
If you are using Microsoft Word, click Tools and then Options.
Once the Options windows pops-up, click the Print tab and UNCHECK Document Properties.
Document properties - Prints the document's summary information on a separate page after printing the document. Word stores summary information on the Summary tab (File menu, Properties command).
Nov 15, 2008 | HP Office Equipment & Supplies
Print stops printing "blue" after first 1/3 of image is printed.
A good self test page indicates that the printer and print cartridges are functioning properly. Something else is causing the print quality problem
Here is a document on this problem:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=1155996&docname=c00211601
Here are the drivers and software: (select your OS)
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&docname=c00211601&product=1155996&
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 29, 2008 | HP Photosmart D5160 InkJet Printer
Only prints last page or least few pages of a ulti page document
if your taskbar displays printer icon on system tray double click on that & delete all privious prints.
select the text or area which you want to print. & give print command, & Click on print selection button & then Print.
Jan 17, 2008 | Lexmark X7170 All-In-One InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
375 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
