Question about Proform 650 Crosstrainer Treadmill
Nothing seems to work
My treadmill is on but, I'm not able to operate any functions.
Treadmill (Nordictrack T9si) stopped suddenly... Power still being received by controller unit, but display doesn't stay lit so nothing functions
open up the control console and look for loose wires... if no loose wires are found, call CoreCentric Solutions and ask if they refurbish that control board... CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
Jul 06, 2016 | Exercise & Fitness
Console does not work it lights up but no buttons function
this just happen to mine this morning, can't find a fix. Help!
Mar 17, 2014 | Nordic Track Nordictrack Exp 1000...
Proform treadmill motor shuts off after a second or 2
There may be a problem with the LCB or motor.
I repair this brand for the distributer in Australia.
Dec 14, 2013 | Proform Crosswalk 500 Treadmill
The treadmill speed is faster than reallife speed. I can easily run 7 minute miles on the roads (not racing, just running) and my wife is an eight minute metronome. But on the treadmill if I set it below...
the speed of treadmills are based on the companies regulations and are machine made. so they might not be 100% accurate. a treadmill is a simulated devise so it is never the same. var fctb_tool=null; function FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976']); delete document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976'] var fctb_tool=null; function FCTB_Init_6836227ebca14782a6c9f0284529fff9(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6836227ebca14782a6c9f0284529fff9(document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']); delete document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']
May 05, 2011 | NRS Sole S77 Treadmill
I have a proform j8li treadmill, all 4 led lights work properly. Console lights all seem to work. Incline works fine but no belt motor function
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Jan 26, 2010 | Exercise & Fitness
Bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Jun 14, 2009 | Bowflex Treadmill Series 7
None of the commands will function
function SubmitGForm() { var ctlForm = document.forms.namedItem('cse-search-box'); var mainForm = document.forms.namedItem('frmSearch'); ctlForm['q'].value = mainForm['_s'].value; ctlForm.submit(); } // Tags: Related Searches: treadmill
--> >> All Products > Microsoft > Windows XP Home Edition > Troubleshooting To solve your problem, re-install Windows, or contact the manufacturer of the hardware for technical support.
May 24, 2009 | Microsoft Windows XP Home Edition
Proform 650 Crosstrainer Treadmill Logo
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
