Question about straighttalk.com
Screen locked in emergency call mode
Can't clear screen
    Problem Solver:
  • 7 Answers
Try shutting your phone off then turn it back on.
Posted on May 02, 2014
How do I get rid of emergency phone
"If you set a lock screen on your Android device, the PIN entry screen will then feature an Emergency call button toward the botto" of the screen. The button will enable anybody who grabs the phone to at least be able to dial 911 in the case of an emergency without needing to enter a PIN or lock pattern."
Download HiLocker App from Google Play. " Launch the app and Turn on Hi Locker App. Make sure you Turn Off, System Lock in your Mobile. Open Lockscreen Settings in mobile and select "none" to prevent from showing double lock screen. You can also download more lock screen from Google Play Store for removing Emergency Call button."
The above are quotes from Google.
Jun 12, 2017 | Cell Phones
MY ZTE BLADE C310 WONT SHOW A KEYPAD WHEN SWITCHED ON
See if you can get to the settings for Mode - most phones lock into "Emergency Mode" if a call is placed to 911. There should be choices for Normal, Airplane and Emergency.
Jun 02, 2016 | ZTE Cell Phones
Razr V: how do i clear the emergency call screen? just appeared, no way to delete or bypass? thanks.
Wayne
You have to have a SIM in the phone if you don't have one. Otherwise Emergency calls only. If you do have a SIM but you are getting that it means the Sim is not detected or is inactive or you've pressed emergency call and the phone is locked. You should have a back button to dismiss emergency dialer and enter pin or pass code.
Mark
Motorola Support
Feb 22, 2015 | Motorola Mobility RAZR V XT885 Android...
How to get a boost max phone out of emergency call mode
EMERGENCY CALLS
Emergency calls can be made in all device conditions as long as there is any
available network signal. From locked screen conditions press the Emergency
Call button to open the dialler, then dial 000 and press the handset icon to
make the call. In all other conditions press the Home key to return to the
home screen then press the handset icon to open the dialler. Enter the
Emergency number (000 or 112) and press the handset icon to make the call.
Aug 13, 2014 | Cell Phones
Zte n910 is locked need to hard reset for zte n910
Warning Hard Reset will erase everything on your Device !
You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
1. From the Home screen, press the Menu Key and touch Settings.
2 Touch the Privacy
4 Touch Factory data reset.
5 Touch Reset phone.
6 Touch Erase everything.
Apr 16, 2014 | Clear Screen Protector - ZTE Anthem 4G...
Motorola F3c handset is showing ' locked 1-100' on the screen. No other buttons work except for emergency calls. How do I release this lock?
motorola F3c handset is showing ' locked 1-100' on the screen. No other buttons work except for emergency calls. How do I release this lock?
Oct 26, 2009 | Cell Phones
I'm stuck on the yellow screen thats says "refreshing"
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
May 25, 2009 | LG KU990 Viewty
Is there a waay to lock the keys while it is in my purse?
this should help you out.
Basicall press MENU > *
Lock the keypad
To lock the keypad to prevent keys from being
pressed accidentally, in the standby mode,
select Menu, and press * quickly; to unlock,
select Unlock, and press * quickly.
When the keypad lock is on, calls may be
possible to the official emergency number programmed into
your device.
Enter the emergency number, and press the call key. The
emergency number you have entered may not be displayed on
the screen.
Apr 19, 2009 | Nokia 1600 Cellular Phone
Help please
This tip unlocks the 3 digit security lock.
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
http://shop.sidekickskin.net/Sidekick-Tips-Tricks
Mar 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
How to do it
Clear 3 digit privacy lock on a Sidekick
straighttalk.com Logo
57 people viewed this question
Top straighttalk.com Computers & Internet Experts
Jerry Kramer
Jerry Kramer
 binay biswas
binay biswas
Are you a straighttalk.com Computer and Internet Expert? Answer questions, earn points and help others
