External speaker port only works when grounded to back of panel
    Top Expert:
  • Computers & ... Master
  • 26,206 Answers
Sounds like half of the amplifier is not working properly, if it has a bridge system.
Posted on Mar 18, 2014
I plugged in external speakers but get no sound. Is there somewhere in a menu to turn the speaker ports "on"?
In almost all the led tvs there is an option in the menu to select whether you wish to use internal speaker or the external speaker. You have to make the after putting an external speaker.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Televison & Video
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
Can i connect this tv to external speakers
Look on the back of your unit, if you can hook this up to external speakers you will see one or more Audio OUT ports. Usually TV's have these audio out ports for Home Theater systems.
Hope that helps!
Jul 19, 2011 | Panasonic Televison & Video
Why my external speaker doesn't work even it's connected with my system?
Good day
Better check the speaker first for loose wires near the plug, then if its ok the second thing you need to check is you computer and by using a tester check if the ports for speaker is grounded or not. If it is indeed grounded better provide or buy another sound card.
Apr 04, 2011 | Computers & Internet
I have lost my owners manual for this set and I want to attach external speakers to improve the sound quality. What impedance should I use and how do I set the t.v. for this operation.
I have 2 Samsung's. One is a series 3 one is a series 5. Both are very similar in the setup so I hope this is helpful. I have both tv's hooked up to external speakers.
First step is to figure out what kind of connect you will use. There is a 3.5mm Jack on the back of the Samsung models the is labeled as EXT. There is also the Optical cable port which will give you better sound. So you need to see which of the ports your speaker system has.
Second go into your menu - speaker settings - and at the bottom it will give you the option to use external speakers. Choose that.
Now that should be all you need to set your tv up for external speakers.
Mar 01, 2011 | Samsung Televison & Video
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
External speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
