Question about Symbol Lot 4 Ls1902t-1000 Barcode Scanners
Scanner is adding the characters }w before bracodes.
I have two scanners doing the same thing. One was working fine until I tried to turn off the enter function, and now it puts }w before barcodes. The second beeps four times with a red light that stays on. I got that one to work, but it was putting the }w characters as well, and now it's just beeping again. I have tried defaulting multiple times, and even downloaded Symbols program which doesn't even recognize the scanner. Since they are so out of date, the support center basically wished me the best of luck. I have run out of ideas.
    Problem Solver:
  • 82 Answers
Do you have a configuration manual book?
I think you can go to factory settings from there.
Posted on Jun 10, 2014
SOURCE: the scanners won't scan information after being programmed
I would scan default barcode again. If you are using PS2 connectors. Scan barcode for PS2 keyboard. And USB for USB connectors. Most likely it is not seeing the device. Or treating as a keyboard as it should.
Posted on Jul 06, 2007
SOURCE: Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Posted on Oct 17, 2007
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
  • 74 Answers
SOURCE: 4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Posted on Oct 23, 2009
  • 74 Answers
SOURCE: Symbol scanners (several models) not recognizing Code 39 Extended
The barcode must be a Code 39 barcode, not a Code 39 Extended or Full ASCII barcode. The Enable Code 39 Full ASCII must be scanned from the Symbologies section of the LS2208 Product Reference Guide (page 186 of 342). The Enable Function Key Mapping barcodes would have to be scanned if you are seeing something other than the tab happen when you scan into your application. In Word, for instance you will see the italics enable/disbled whenever the $I is encountered in the barcode.
As for the Covert to Code 39 Full ASCII- that is for Wand and Scanner emulation. The setting was having no effect because you were not connecting to either of these hosts.
Posted on Oct 26, 2009
Why Symbol LS2208 keyboard wedge not scanning correctly?
Do you have more than one of this model scanner? If so, I would test a different one on the same computer to make sure it is not a computer issue. Be sure to test it in the same USB port to get an accurate test.
Having a second scanner would also allow you to switch out the cable connecting the scanner to the computer. The end of the cable which plugs into the scanner is an RJ45/Ethernet end. You will need a flat head screw driver to push down on the tab to release it from the scanner. Swap the cables and see if the problem follows the cable or the scanner. If it follows the cable, you can replace the cable for cheap. If it follows the scanner, I would plug the scanner into the working computer and reset the scanner to factory default using the Symbol Book of programming barcodes.
Try a different USB port with the original scanner.
You can also reset to factory default if you don't have a second scanner using Symbols book of programming barcodes.
Sep 20, 2014 | Symbol LS2208 Handheld
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
My hp laserjet 3330mfp reports a scanner bulb is warming up and it never goes off. I have tried to unplug then plug back in. The printer works fine.
Here is how to cold reset the machine. also I added some addtiona options below as well.
1 Unplug (or turn off) the product from the power source.
2 Press and hold down the * and menu/enter keys.
3 Continue to hold down the keys while you plug back in (or turn on) the product, through the entire power on sequence.
4 When the control panel display reads Permanent Storage Init. release the keys.
5 Allow the product to return to Ready before using the product.
If that doesn't work it can be a power related issue,
- Make sure it's NOT plugged in to a surge protector.-
- Try a different outlet on the wall.
if theses steps fail you will most likely have to replace the scanner assembly
Another Option you can try as well :
Also I found this on a HP forum NOT SURE IF IT ACTUALLY WILL WORK:
" Scanner Bulb Walkout - Unplug the power from the unit,plug the power back in wait until the unit reads "Scanner Bulb Warming Up" Unplug the unit. Repeat this step 5 times.
This should move the scanner assembly back to its home position.
link to this post : http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=989123
Oct 20, 2010 | HP LaserJet 3330 All-In-One Printer
My scanner was working fine until I held down the lock button. It didn't actually turn on the key lock (the key symbol didn't come up on the display) but now none of the keys respond to presses. I tried...
When you reintilize the scanner, it should lose all programming and settings. Hold down the Tune/Clear button while pushing the reset button. Do not release the Tune/Clear button until the display clears and returns.
Aug 14, 2010 | Radio Shack Pro-82 Scanner
Scanner not found.
first check all your wires make sure nothing has come loose.
unplug the power supply wait a minute and re power scanner.
Also, turn off you PC and restart it.
retest your scanner
if it still does not work then..
next try reinstalling your scanner driver software on your computer.
If these beginning steps do not work please write back for further diagnosis.
Mar 26, 2010 | HP Scanjet 4370
Error message
hello..... try to remove the scanner driver located at ad and remove program.....how to do this?
go to start din control panel and click the words( ad and remove program) click it and you can see the other window appear name currently install files look bellow the currently install files and you can see the scanner driver high light it and click uninstall..restart you pc to take effect..and install it again...after all if no changes
reformat your pc using os/operating system cd.. and install the scanner driver again.. thank you hope i cant help you... have a good day!!!!!!!!!!!
Jul 06, 2009 | HP Scanjet G4010 Flatbed Scanner
Umax Mirage II Flatbed scanner,3 flashing lights
Could be a SCSI termination issue. Try changing the SCSI address number on the scanner to a different one and make sure the chain is terminated properly. If there are multiple SCSI devices in the chain, disconnect all the others until you are sure the scanner is working then slowly add the other devices to the chain making sure everything works as each device is added. SCSI voodoo!
Jun 26, 2009 | Office Equipment & Supplies
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Symbol Lot 4 Ls1902t-1000 Barcode Scanners Logo
103 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
