Question about Sirius Hoods SU3
How to fix grinding noise coming from Sirius SU3 wall mount hood?
Motor makes grinding noise. can't figure out how to remove it to fix it.
2 Suggested Answers
SOURCE: I have a Sirius range hood SU3. It sound like the
Yes, I am on my third motor in a SU 4/ Sirius is brutal to deal with. All of the motors are **** and they are always back ordered. here in Canada the distributer change around 2008. They are through Maroline and a crappy company to deal with unlike the othe people in Oakville. Service sucks for such an expensive and beautiful stainless hood. Good luck and the motor does come off...
Posted on Feb 15, 2011
How can tell which lower motor mount is bad on my 2004 chevy impala 3.4 liter ? Does a bad motor mount make the engine have grinding noises after running the car?
With the park brake on, start the engine with the hood open so you can see it through the windshield. Put it in reverse and give it some gas, if the engine moves up, you have a broken mount. Do the same in drive. If the motor moves up then the mount on the side of the engine that moved up is broken. If these tests don't show a broken mount then your grinding noise is coming from elsewhere.
Jul 28, 2017 | 2004 Chevrolet Impala
How do I replace the chuck in my drill? It is making a grinding noise.
Chucks DON'T make grinding noises!!!!!
The grinding noise is probably coming from the REDUCTION GEARBOX which is located behind the chuck [the shaft upon which the chuck is mounted comes out of the gearbox].
There are usually four (4) screws mounting the gearbox housing/cover onto the motor/handle section of most drill/drivers.
The cause of most grinding nioses originating in the gearbox is lack of lubricating grease between moving parts.
Jun 02, 2013 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Mar 07, 2013 | Sirius Hoods SU3
Hello, have a sirius range hood 600-cu.ft./min of power, 4-speed fan, electronic controls, halogen lighting. its not working at all. press controls, nothing, power is going to it, checked that. what you...
Check for power in and out of the main control board...sounds like the main board has fired...if you have power going in, but none coming out then the board is bad..
heatman101
May 02, 2011 | Sirius Hoods SU3
I have the Saeco Incanto Sirius. It makes grinding noises but does not dispense coffee, just hot water.
The grind might be too fine or the grind chamber is blocked, remove brew unit and check the door covering the grind chute to make sure it is clear, or adjust towards coarse about 2 numbers.
Apr 13, 2011 | Saeco Incanto Sirius Espresso Machine
I have a Sirius range hood SU3. It sound like the right side of the fan blades are off-balance, because it's making a scraping noise. It is starting to get annoying. I looked at it and I don't see a way to...
Jan 05, 2011 | Sirius Hoods SU3
Hood fan is turning on and off by itself, won't stay on or off.
What devices in the room were checked. A vent hood will sometimes run on what is called a humidistat, and anytime it senses high humidity it will kick the vent fan on. Check to see if this is the issue, if so and this hasn't happened before try changing the humidistat.
May 03, 2010 | Sirius Hoods SU3
My Life Fitness 9000 Treadmill is making a loud rattling noise when i use it which is getting louder. THe belt is fine and i cannot see any loose parts. It sounds like a grinding noise. There is a lot of...
Could be a number of reasons - where is the black dust coming from? remove the motor hood and check for misalignment of the drive belt from motor to the front roller.
Apr 06, 2010 | Life Fitness 9000 Next Generation...
Sirius Hoods SU3 Logo
113 people viewed this question
Top Sirius Kitchen Ranges Experts
Thomas Perkins
Thomas Perkins
Zeagle
Level 1 Expert
ray gallant
Are you a Sirius Kitchen Range Expert? Answer questions, earn points and help others
