Question about Gateway SX2800-01 PC Desktop
PC Not Turning On
My desktop was not turning on. I already checked the power supply. Today i pulled the display card and my pc turned on. Is That means display card is gone? Is that right. Because if I put the display card back in and try to turn pc on it doesn't turn on. Please help
    Novelist:
  • 126 Answers
It may mean that your video card driver is corrupted. Pull the card, start the computer, and remove the video drivers. (If you know how, remove them from the backup directories, too, just to be safe.) Then try to reinstall the video card just like it was new.
Posted on Mar 18, 2014
What does power down pc and plug in cabkes for gpus mean, even though they are already plugged in bad card?
Added a new graphics card? Today, high-end gaming graphic cards (GPUs) need separate power from the computer's power supply; they take more power than the motherboard can give them through the connector under the card. Your power supply should have separate connectors that match what's on the new video board.
Shut your computer down, pull the plug, open it up, and connect the power supply to the card, and then you'll be fine.
Sep 11, 2014 | Dell Alienware Area51 Alx Gaming Desktop...
Gateway SX2800-02H not turning on
Hi, To check the powersupply you will need to probe all connections.
Get a digital volt/ohm meter and check them all. Go to Youtube.com and search for how to repair PC. Watch all video's on how to.
Hope that helps.
PS. Hope the board is not fryed. (toast)
Mar 17, 2014 | Computers & Internet
Monitor does not come on
Hi Scott,
please check the removing the vga cable of monitor and turn its power on and display must show no signal error itself you can see it very clear text on it.
if your monitor good check the cable and plug it back to pc.then turn on the pc.if computer starts you can hear the HDD sound and please note the Beep sounds comes up or not ,if continues beep comes up problem can be with your pc memory modules or vga card ,sometimes mother board,
clean the ram card using smooth brush and mother board also.
unplug the power supply jack and re insert it .
remove the vga card also and do the same.
first all check the power unit fan is turning on when you press the power button too...
please let us know the results or come with more details.
regards.
nuwan
Jan 08, 2014 | Dell Dimension 3000 PC Desktop
Gateway sx2800-02h not turning on
I was working on my desktop, it flickered twice and then there was no display. Pc turned off and not turning back on. i checked the power supply its working, but when connected to motherboard its not turning on. What could be the reason?
Dec 20, 2013 | Computers & Internet
Acer Aspire M1641 Desktop, Turns on, Powers up, disk spins, main fan turns, lights, display stay black, will not display.
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
You computer system is not POSTing, it has failed the Power On Self Test!
Go through my published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Hopefully it is just a connection problem!
Thanking you!
damnor01
Mar 03, 2011 | Acer Aspire M1641-U1521A PC Desktop
There is no power distribute to the computer the low voltage power supply clicks put no power is distribute to the rest of thecomputer
There's a lot of reason why your computer is not turning on. If you said that when you trying to turn on your computer it sound beep or clicking. Try to feel or look at the back of your system unit if your power supply fan turning. If it's turning there is no problem with your power supply unless you test it with multitester. If no display but your computer is on, it means that you have to check your memory or video card try cleaning pin of your memory and video card. First you have to electro static discharge by holding the chasis of your computer, because the computers component is very sensitive to electro static. Good Luck
Nov 12, 2010 | E-Machines (T2958) PC Desktop
No video many different video cards hp pavillion a1410n
too much troubleshooting... not common..
let it check to computer technicians.. it might be you motherboard..
because if you turn it on the fan still turning (Power supply ok!)
minimize from turning it on..
Nov 30, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Built-in video card
you can't enter cmos due to no display pc must have display first. check another power supply.
May 30, 2009 | Dell Dimension 4600 PC Desktop
No display on monitor
Check your RAM card and Video adapter .Because problem of one of that thing computer wont on the monitor video.
Jan 10, 2009 | Intel Desktop Board D845EPI Motherboard
PC is dead
I assume you installed the new graphics card already. Did you check if your power supply could handle the increased power? If your power supply is rated at 350W or less, I'd upgrade to at least 400W.
Also, ensure that the graphics card, if it has a power connector, is connected properly to the power supply, and that in the process of installing it, you didn't accidentally remove any of the power connections to your motherboard.
The Green LED lets you know that it is receiving power from the wall, and that the problem lies in the computer somewhere.
Dec 30, 2007 | Computers & Internet
Gateway SX2800-01  PC Desktop Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
