Question about Kicker ZX1500.1 Car Audio Amplifier
Green light power stay on speaker cut on in off when turn up
Green light power stay on sparker cut when u turn up on the amplifier
2 Suggested Answers
SOURCE: speakers cut off when bass goes up...
you may be running 2 low of ohm load
Posted on Feb 14, 2009
Everything did work but kept blowin fuses by the battery. Now a red light stays on, on the amp & the blue/green power lights dont *** on. What should i do?
Check all of your power connections, your speaker connections and battery connections. if all are good and clean (no shorts/wires touching) then try unhooking your speakers and see if the lights come back, if that helps then you have problems with your speakers, if not then amp is bad. I hope this helps ya.
Randy
Feb 17, 2011 | Phoenix Gold Titanium 800.1 Car Audio...
I have a Sonamp 260 MKII. The red light is on but the green light does not come on. I've unhooked all speaker wires and input wires. Now what?
The red light will stay on without speakers connected.
Make sure your speakers are good and try again
If it still fails then there's a power supply failure internally
Aug 02, 2010 | Sonance Sonamp 260 MKII 2-Channel...
My Clarion APX480M marine amp cuts out at random
try to unplug each speaker one by one while playing it. There can be a defective speaker that grounds out at the speaker terminal or internally causing the amp to go into protection causing all the speakers to go out.
Jun 05, 2010 | Clarion APX480M Car Audio Amplifier
I just got a sony xplod 1000 watt amp i got everything hooked up and when i turned the key the power light chaned from green to red. i check over the amp again and again, i cant find any thing wrong........
Try disconecting all speakers from the amp, turn it on after and if it stays on red it sounds like it had kicked the bucket. if it stays green start from their and check all of your wires for shorts (speaker wires) again. hope this helps...
May 08, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
Dec 24, 2008 | Sony XM-2200GTX Car Audio Amplifier
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Rt 202 led light red and no sound
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Jun 03, 2007 | MTX RT202 Car Audio Amplifier
Kicker ZX1500.1 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
