Question about Nokia 6630 Cellular Phone
MMc Mobile Memory card
Please I was openning an Application in my phone, but i was openning it through the memory card, so i forget to stop it, and i immediately removed the memory card and now is tell me that memory card unavaliable, or it will tell me please insert memory card.
Please what can I do to Recovery the damaged Memory card. i just want to get my memory card back, because is a 1GB card. I put it i a card reader, but it was not recognised, so what can I do. please.
  • 490 Answers
Re: MMc Mobile Memory card
Try by restoring ur handset and formating ur memory card once...
Posted on Nov 10, 2007
Put ur memory card in the card reader
right click the selecteddrive and select formatt
select the file system to be FAT
Posted on Dec 31, 2008
Cannot open my messege nokia 6630 save in memory card
Posted on Jan 30, 2008
0 characters
3 Points
Multi media cards (MMC) or simply memory cards have been a very essential part in mobile phones off late. People who have high resolution mobile phones or people who use their mobile phones as a pen drive essentially require a MMC that has the space to store those files. Worried about the security of the cards, they try to protect it behind a password. The problem with password for a MMC card is very huge. In case you forget the password, all you can do is throw it in a dustbin and buy another. You may try to format the whole card using a computer which sometimes may not be possible due to some important files stored in it. And even if you dare to format it anyway, an error appears on the desktop, saying 'you do not have enough permission's to format'.
What if someone mischievously kept a password for your MMC without your notice?
If you use a Nokia mobile, fortunately, you have an application which can find your previous forgotten password or lost password. You may have heard of 'FExplorer'.
It can be used to go through (Search) your disk and see your lost password.
Just Download the application, transfer it to your phone and install it.
Once installed, go to 'C' disk and then click on the 'system' folder. Scroll down to find 'mmcstore' and open it using the editor (click on options -> file ->Editor/Viewer).
There you go, your saved password is right in front of you which made you mad all these days.
Note: This method only works when the 'phone memory' has not been formatted since the password is lost.
Apr 10, 2011 | Cell Phones
I have forgotten my password of Memory card of sandisk SD 2GB . i need the secret code if there is any . so please help me .
hi de
there are 2 solutions
1)insert the memory card in that phone in wich you locked the memory card,then install y browser in the mobile,open c drive in y browser go to sys folder and then go to bin folder,there you will see a file named mmc.dat open it with notepad,you will find your mmc password
2)insert the mmc in a s60v5 mobile(5233,5800,5235)and format the mmc,this will delete the password and your mmc will be unlocked
Mar 27, 2011 | Nokia 6303 Cell Phone
I forgot my password of memorycard so please tell me how can i unlock my memory card?
There is a application named FExplorer by installing this in your mobile you will be able to get the password of it .
The FExplorer installs on the symbian OS Mobile only
Please refer the following link
Nov 02, 2010 | Nokia 5310 Cellular Phone
Nokia 3110 mmc problem
sir nokia 3110 mmc not show in gellry
Apr 02, 2010 | Nokia 3110 Cellular Phone
I have forget my security code of nokia N72 my imei no is 359726002105168.please anybody help me
try these:
You need 1 mobile phones and a memory card reader.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
memory card reader. Create
the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345".
Feb 10, 2009 | Nokia N72 Cellular Phone
Unlock memory card
when the card is inserted in the mobile, go to memory card option and click the option set new password
Jan 01, 2009 | Nokia 6600
Nokia 6681
u will need a computer with nokia pc suite installed on it ,a dku cable n ur mobile ofcourse wid memory card inserted in it.
open my computer,
click on nokia phone browser icon i.e.,one of the removable drive.
a window will open displaying ur nokia phone model i.e.,nokia 6681,dbl click on it.
next window will display ur phone memory and memory card.
right click on memory card,select copy from drop down menu.
copy it to ur other computer drive (c,d,etc)
disconnect the phone
insert new memory card
copy the mmc data from drive n paste it in new mmc.
Oct 21, 2008 | Nokia 6681 Cellular Phone
Nokia 7610 - MMC Password
put ur locked memory card in N70 and format it... hope it will work... or go to some mobile repairing shop there you'll find a tool called MMC-unlocker... they will unlock it if you want your data back...
May 09, 2008 | Nokia 7610
Memory card password remover
i have nokia 5310. i cannot remove my password of memory card because i have forgot it. i have no idea about it cannot be remove so please give me a solution
Feb 19, 2008 | Nokia 6233 Cellular Phone
Hi You can`t install applications on the memory card,you have to install it only on your phone memory. Good Luck
Aug 23, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Nokia 6630 Cellular Phone Logo
138 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
