How to connect a teac equalizer A220 to a Sony receiver str-DH540
  • 41 Answers
I'm not familiar with your units. The most common set up would be use the "tape monitor loop". Eq out to receiver tape in monitor, Eq in to receiver tape out monitor, then engage receiver "tape monitor" switch on.
Posted on Apr 05, 2014
5 Suggested Answers
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site...
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510
Hope that helps.
Posted on Oct 19, 2007
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
renosean
  • 492 Answers
SOURCE: receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Posted on Jan 04, 2009
OnlyOneN
  • 86 Answers
SOURCE: How do I connect my Lenovo X200 Tablet to my new
Couple things to be aware of:
1. The X200 is not available with a Blu-Ray drive. So, your HD content will need to come from somewhere else, such as downloading from iTunes. Alternatively, you can purchase an external Blu-Ray drive. (it may be cheaper / easier to buy a dedicated Blu-Ray player if that's the route you want to go).
2. The X200 only has analog audio output. The only surround you'll be able to receive is Dolby Pro-Logic, provided your source material has it encoded that way. You can connect your laptop to the receiver via a 1/8" to RCA adapter, available at virtually any electronics retailer. (Buy the cheapest one you can find) Connect the 1/8" plug to your headphone jack on the laptop, and the white and red RCA connections to any available input on the back of your receiver. (such as CD, AUX, DVD, etc.) Select that input on the front of your receiver and you'll hear the output of your laptop. Enable surround sound processing (pro-logic) on your receiver. Check the manual for instructions on how to do that.
3. Purchase a VGA cable (I recommend monoprice.com ). I suggest staying under 15' for optimal quality. Connect one end to your laptop, and the other to the PC-in on the back of your TV. Select that input using your TV's remote. (On my Sony, I press Menu, External Inputs, then PC)
4. Set up your laptop to use the external monitor. I suggest leaving your laptop off till you plug in the VGA cable. If upon booting your laptop is outputting to the TV display, usually a key combination such as Shift-F7 will enable it.
Alternatively, your TV has an 1/8" audio input jack that goes along with the PC input. If you've connected the audio out of the TV to your receiver already, the audio from your laptop can pass through the TV to the receiver. 1/8" cables can also be purchased from Monoprice.com.
Let me know if that helps!
Posted on Apr 20, 2009
Do you need a pre-amp to connect this turntable to a receiver that has no Phono input jack?
Yes, a TurnTable can be connected to any of the Analog Audio Input ports on the Sony STRDH130 Receiver. However, the turntable signal will need amplification from an external pre-amplifier (or an inline amplifier) as this Receiver does not have a PHONO input.
Feb 16, 2018 | Sony Audio Players & Recorders
My receiver says the speakers are off
Maybe you can update the speaker driver to see whether it is a driver problem.
Apr 09, 2015 | Sony STR-DH540 5.2-Channel Home Theater...
I Bought a Sony STR-DH130 2-Channel Hi-Fi Receiver and a AudioSource EQ 200 Graphic Equalizer. I connected them and the equalizer does not make a difference nor does it change the sound, can someone
Well i have a equalizer, some times and just(studio gear) the output from my mixer connected to my equalizer and that output to the monitors., It might be a wrong connection orrrr have you put the equalizer on the receiver input signal, that signal has to be the right impedance and your receiver will propably make the signal linair, so that,s useless
Oct 05, 2014 | Audio Players & Recorders
How do I get solve this problem: the str-dh540 has no output?
Take everything to the nearest Sony-authorized repair depot, for professional trouble-shooting and repair.
May 20, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
I cannot get components to work through sony str-dh540.
two things come to mind
- Low input voltage
- Power supply issues
Low Power
As multiple items are having issues the issue sounds that a wiring issues. Have you tried another receptacle (plug) perhaps another room Try plugging only a light to the plug. Does it flicker or appear dim. A multi meter to check line level and a polarity tester to check that wiring is correct. A good power bar will have a polarity tester built in.
Power Supply.
When you must turn on and off a device before it starts working suggests that components have partially failed. Bad capacitors can exhibit this type of issue.
It is possible that a power issue is damaging your hardware. It is always best to use a good power bar. Passive bar are good for a few years. Active should work well for many years. Balance the cost of a power bar to the value of your equipment.
Jul 18, 2017 | Sony STR-DH540 5.2-Channel Home Theater...
Using an equalizer with a Sony STR-DE 475
I think I must have missed something. Where does the EQ get hooked up to on the Sony STRDE 475? Thanks, Nicolas
Nov 22, 2012 | Audio Players & Recorders
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
you need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
Nov 13, 2010 | Sony STR-DA2000ES Receiver
Need to wire a teac eqa20 to a sony reciever
record out from receiver to equalizer in equalizer out to tape in
Mar 26, 2009 | Teac EQA-120 Home Equalizer
SEQ-711 connection to sony STR D350Z
You can use the VCR audio connections for a stereo analog processor
Many people want to use an EQ with their modern multi-channel Digital Sound Processing gear but at best an analog 2-channel EQ (or any other processor) will only work with analog stereo sources. On most receivers, simply selecting the Tape Monitor disables all digital inputs. However, most DSP can still be employed with analog source material and a 2-channel processor with varying degrees of aesthetic pleasantness. Beauty is indeed in the ear of the beholder.
If that works for you, go for it. I do it, but I fully understand the limitations.
Mar 15, 2009 | Sony SEQ-711 Home Equalizer
83 people viewed this question
 Grubhead
Grubhead
