My clok tcr338 alarm1 keeps flashing on the display unable to change any settings and reset button does nothing
The display flashes 12:00 and above the time the alarm1 button flashes I am unable to do anything like change the time turn radio on etc. It had been working just fine and was like this when I came home. tried reset button but nothing changes
  • Maureen Grumbles
    Maureen Grumbles Mar 21, 2014
    the clok tcr338 has always worked normal when i came home I noticed the display was flashing 12:oo and above that the alm1 box was illuminated and flashing. none of the buttons are functioning I cannot adjust the time I cannot turn the alm1 off I cannot access the radio features, when i depress the time button and the alarm 1 button the flashing alm1 disappears but soon as I let the buttons go the alm1 box is back and flashing. I have no clue as to what could have happened as noone was home all day and no one touched it it just suddenly started to malfunction. I tried pressing the reset button but nothing happens with that either. I really like this model as it is small and also has aux in for my mp3 player. anyone have any ideas?
  • 29 Answers
SOURCE: D70 digital camera
could be bent pin in the memory card slot
Posted on Jan 09, 2006
  • 3 Answers
SOURCE: Can't set the time
You can disable the daylight saving time function using the DST switch. Setting the time requires you to slide the 4-position slide switch on the top rear to the right to set the time.
Posted on Nov 16, 2007
JigSaw007
  • 157 Answers
SOURCE: radio does not work
ok, there is a high possibiltiy u have a loose connection.
When it disconnects, it causes the time to go to 12:00
The power supplying ur radio is intermittent. You may have bounced on something while u was driving which caused the loose connection.
You may wanna have a look at the connections at the back of the radio and make sure the power is connected correctly
Hope this helps
Cheers
Posted on Aug 18, 2008
SOURCE: Flash settings Sony DSC-H7
I had the same problem with my DSC-H9. The flash setting is set off when in BURST record mode. Go into MENU, scroll down to REC Mode, change it back to NORMAL.
Now go shoot someone or something... with your camera of course!!
Posted on Oct 31, 2008
Acuraking
  • 42 Answers
SOURCE: How to change the time on clock radio
I'm not 100% sure if this is right or not, but i used to have one similar and the way to reset it was:
  1. Press the SET button.
  2. After the time blinks, press the REV or FWD button to adjust the time. (Press and hold the REV or FWD button to fast reverse or fast forward time.)
  3. To save settings press the SET button.
  4. Once you have the clock set and have press the SET button, the time should be done blinking.
Give this a try and hopefully it works, good luck
Posted on Nov 10, 2008
How do I set a tcr338 clok? I can change the minute, but not the hour.
Try this,
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button"
2. While holding the Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the Button to set the clock
Feb 19, 2016 | Watches
How do I re-set my CLOK TCR338 to not read in military time?
heres an answer another question had that might assist u in some way:
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Dec 05, 2014 | Watches
How do you set this atomic clock C17D2090 (WIC#628865)
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Aug 16, 2012 | Audio Players & Recorders
I dont know how to set the alarm for the studebaker SB2103BW? can you help me?
With the radio turned off-press and hold the clock button until the hour flashes- use the select buttons to move number up or down. Press button to make minutes flash and adjust as above. To set the alarm press the display button until hours start flashing and change with the select buttons. Use the clock button to change from hours to minutes and also from alarm1 to alarm2.
Apr 13, 2011 | Spectra Studebaker SB2103 Clock Radio
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Mar 26, 2011 | Audio Players & Recorders
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
How to set clock clok tcr368
Setting the CLOK TCR368 is done by having the unit:
Turned OFF - The power button is located at the top left face of the unit.
Press and hold the CLOCK/DISPLAY/PLAY/PAUSE button for at least 4 seconds. (It is located to the right of the power button at the upper left corner of the unit.) Do not let go of the button.
While holding down the CLOCK/DISPLAY/PLAY/PAUSE button, press the HOUR and MINUTE buttons to the correct time.
Release thethe CLOCK/DISPLAY/PLAY/PAUSE button.
The backup battery is to keep the clok circuit running in case of a power failure and can't be used to power the radio.
With the unit OFF, press and hold the FUNCTION button (located between the ipod slot and the snooze button) for at least 2 seconds. The display will flash either 12 hour or 24 hour depending what mode it is in.
Release the FUNCTION button and press it once to change the mode.
Press again to cycle between the 12 hour and 24 hour mode.
When the display indicates the mode you prefer, simply wait 2 seconds for the clock to go into that mode without pressing anything.
Sep 20, 2009 | Digital Products International Clok Smooth...
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Mar 25, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
Casio g-shock watch
http://world.casio.com/wat/download/en/manual/
try for the manual from here.
riz.
Nov 06, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Daylight Savings Times Changed
Oct 29, 2007 | Emerson Smartset Clock Radio
20 people viewed this question
 Grubhead
Grubhead
